AppServers Blank Title 91457
What os are you running on the desktop? I have found if you are running vista you need to turn aero off. Aero does not play well with Epicor. We changed all of our clients from aero to vista basic and the performance issues went away.
Hope this help!
Jason
From: vantage@yahoogroups.com <vantage@yahoogroups.com>
To: vantage@yahoogroups.com <vantage@yahoogroups.com>
Sent: Mon Jul 05 21:01:39 2010
Subject: RE: [Vantage] Re: AppServers
Yes, tech support should be the people to help you out, be diligent and forceful
in your attempts to get it escalated, it's the only way to get something done.
Be sure to let whoever you initially talk to know that you have already gone
through the tuning guide completely, and make sure you are on the most recent
OpenEdge Service pack prior to calling them.
Things to be checking are on your DB, the Spin Lock retries, the DB buffer,
APWs, lock table entries, message buffer sizes, number of servers, and then on
the AppServers the Message buffer size(Mm), Stack size(-s), and temp table
size(-Bt).
Tuning is an art form not really a one size fits all, this is what you need to
do, lots of variables to check and see how the server reacts to them.
However, with your problems, it sounds like there is a memory problem and I
suspect there is a hot fix out there for OE that you will need to apply.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
brad_boes
Sent: Friday, July 02, 2010 9:16 AM
Subject: [Vantage] Re: AppServers
We have been through the tuning guide and did not see any improvements. We are
new to Progress and the Epicor performance tuning overall.
Is there something specific we should be looking for?
Would tech support be able to help us if we called this in?
Brad Boes
Metalworks
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Ned" <TechnoBabbly@...> wrote:
> For both of you, separating out your Appservers likely won't solve your
> problems, chances are all it's going to do is stretch out your problems to
> happen on a less frequent basis.
> I would consult a performance tuning guide and adjust that before deciding to
> add Appservers to the situation and likely spread out your problem to more
than
> one spot, and increase the administration monitoring for where those problems
> are taking place.
> Chances are there are Appserver settings and .pf file settings that will gain
> you better performance over adding an extra set of Appservers.
> I would also make sure that you have your OpenEdge up to the most recent
service
> pack and hot fix that is available.
> effgroups@...
> Sent: Thursday, July 01, 2010 8:30 PM
> Subject: Re: [Vantage] Re: AppServers
> We went live with 9.04 last week and experience serious slowdowns and we have
> only a total of 11 licenses.
> I will have a look at the doc and see what I can do.
> Ephraim Feldman
> From: "brad_boes" <bboes@...>
> Sender: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> Date: Thu, 01 Jul 2010 17:09:07
> To: <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
> Reply-To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> By bogged down, I meant the the wait times experienced at the client sessions
> are doubling and tripling to open up screens, return part numbers in trackers,
> enter new orders, etc. Tt is pretty much across the board slower.
> It doesn't seem to be "set" time of the day, but it typically worse later in
the
> day.
> We are not live yet and have about a dozen people on at most. We know we can't
> have this happening when all 90+ users are on after going live.
> Also, my database admininstrator says "thanks" to the user group for the app
> server separator document. She said she has been looking for this type of doc
> for a little while already.
> Thanks.
> Brad
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Techno Babbler <TechnoBabbly@> wrote:
> > What do you mean they get "bogged down"?
> > On Thu, Jul 1, 2010 at 7:48 AM, brad_boes <bboes@> wrote:
> > > We are also planning to separate out our app servers, is there a 9.04 or
> > > 9.05 version of this document? Or is it the same thing?
> > > Our app server needs to be re-started everyday because is gets bogged down
> > > in the afternoon, we hope the separating out will help this.
> > > Any other app server advice or tips for newbie database admin people?
> > > Thanks for the help in advance.
> > > Brad Boes
> > > Metalworks
> > > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Bill Wu <billw@> wrote:
> > > > Thanks
> > > Of Ned
> > > > Sent: Wednesday, June 30, 2010 1:59 PM
> > > > Subject: RE: [Vantage] AppServers
> > > > If you log into the Group Page on Yahoo, then you can go to the Files
> > > section
> > > > and there is a document that is about 3/4 down the page posted by Vic
> > > last
> > > > September, it's called Implementing Separate Appservers.doc"
> > > > From:
vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com<vantage%2540yahoogroups
> .com>>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com<vantage%2540yah
> oogroups.com>>]
> > > On Behalf Of Bill
> > > > Wu
> > > > Sent: Wednesday, June 30, 2010 1:03 PM
> > > > To: 'vantage@yahoogroups.com<mailto:%27vantage%40yahoogroups.com><mailto:%27vantage%40yahoogroups.com>'
> > > > Subject: [Vantage] AppServers
> > > > Someone posted some instructions on how to create more AppServers to
> > > separate
> > > > the load. I couldn't find it anymore. Can someone post that again or
hint
> > > where
> > > > I can find it?
> > > > Thanks
> > > > [Non-text portions of this message have been removed]
> > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > > have
> > > > already linked your email address to a yahoo id to enable access. )
> > > > (1) To access the Files Section of our Yahoo!Group for Report Builder
and
> > > > Crystal Reports and other 'goodies', please goto:
> > > > http://groups.yahoo.com/group/vantage/files/.<
> > > http://groups.yahoo.com/group/vantage/files/>
> > > > (2) To search through old msg's goto:
> > > > http://groups.yahoo.com/group/vantage/messages
> > > > (3) To view links to Vendors that provide Vantage services goto:
> > > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
have
> > > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
Please consider the impact on our environment before printing this e-mail
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company. Finally, the recipient should check this email and any attachments for the presence of viruses. The company accepts no liability for any damage caused by any virus transmitted by this email.
Solar Innovations, Inc., 31 Roberts Road, Pine Grove, PA, 17963, www.solarinnovations.com
Someone posted some instructions on how to create more AppServers to separate the load. I couldn't find it anymore. Can someone post that again or hint where I can find it?
If you log into the Group Page on Yahoo, then you can go to the Files section
and there is a document that is about 3/4 down the page posted by Vic last
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Bill
Wu
To: 'vantage@yahoogroups.com'
I can find it?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Ned
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Bill
Wu
To: 'vantage@yahoogroups.com<mailto:%27vantage%40yahoogroups.com>'
I can find it?
http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
We are also planning to separate out our app servers, is there a 9.04 or 9.05 version of this document? Or is it the same thing?
Our app server needs to be re-started everyday because is gets bogged down in the afternoon, we hope the separating out will help this.
Brad Boes
Metalworks
--- In vantage@yahoogroups.com, Bill Wu <billw@...> wrote:
> Thanks
> Wu
> I can find it?
> Thanks
> Brad Boes
> Metalworks
> > Thanks
> Of Ned
> section
> last
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com<vantage%2540yahoogroups.com>>
> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com<vantage%2540yahoogroups.com>>]
> On Behalf Of Bill
> > Wu
> separate
> where
> > I can find it?
> > Thanks
> have
By bogged down, I meant the the wait times experienced at the client sessions are doubling and tripling to open up screens, return part numbers in trackers, enter new orders, etc. Tt is pretty much across the board slower.
It doesn't seem to be "set" time of the day, but it typically worse later in the day.
We are not live yet and have about a dozen people on at most. We know we can't have this happening when all 90+ users are on after going live.
Also, my database admininstrator says "thanks" to the user group for the app server separator document. She said she has been looking for this type of doc for a little while already.
Thanks.
Brad
> > Brad Boes
> > Metalworks
> > --- In vantage@yahoogroups.com, Bill Wu <billw@> wrote:
> > > Thanks
> > Of Ned
> > section
> > last
> > On Behalf Of Bill
> > > Wu
> > separate
> > where
> > > I can find it?
> > > Thanks
> > have
Just out of curiosity, how many apps servers are you using? We have 1 specific for PrintQue processing and then the MFGSYS803. Do you use more apps servers than that?
> Wu
> I can find it?
> Thanks
We went live with 9.04 last week and experience serious slowdowns and we have only a total of 11 licenses.
Ephraim Feldman
To: <vantage@yahoogroups.com>
Thanks.
Brad
> > Brad Boes
> > Metalworks
> > > Thanks
> > Of Ned
> > section
> > last
> > On Behalf Of Bill
> > > Wu
> > separate
> > where
> > > I can find it?
> > > Thanks
> > have
add Appservers to the situation and likely spread out your problem to more than
are taking place.
I would also make sure that you have your OpenEdge up to the most recent service
effgroups@...
Ephraim Feldman
day.
Thanks.
Brad
> > Brad Boes
> > Metalworks
> > > Thanks
> > Of Ned
> > section
> > last
> > > From:
.com>>
oogroups.com>>]
> > On Behalf Of Bill
> > > Wu
> > separate
> > where
> > > I can find it?
> > > Thanks
> > have
Hi Brad,
This is similar to a post I did yesterday.
We are live with Epicor 9.04.503B and we have regular slow downs.
I wouldn't say it is every single day at a particular time but it does happen regularly.
Every night we run a schedule to stop and start the Apps, but we still have to restart the WHOLE server (or restart the Apps and DB) every 10 days (almost on queue).
It is interesting that you are experiencing similar issues.
When you are live, you can imagine the disruption/loss of time because it is slow or because we have to restart the db etc and kick everyone out of the system.
We only have about 30 users and it causes major disruption - I can't imagine how much disruption it would cause if you have 90 users.
I have been speaking to Epicor about this issue for 10 months and we arent really any further forward with regards to a solution.
I would be interested to hear if you find a solution to the slow downs.
Thanks.
Sent: Thu, 1 July, 2010 18:09:07
Â
Thanks.
Brad
> > Brad Boes
> > Metalworks
> > > Thanks
> > Of Ned
> > section
> > last
> > On Behalf Of Bill
> > > Wu
> > separate
> > where
> > > I can find it?
> > > Thanks
> > have
We have been through the tuning guide and did not see any improvements. We are new to Progress and the Epicor performance tuning overall.
Brad Boes
Metalworks
> are taking place.
> effgroups@...
> Ephraim Feldman
> day.
> Thanks.
> Brad
> > > Brad Boes
> > > Metalworks
> > > > Thanks
> > > Of Ned
> > > section
> > > last
> > > > From:
> .com>>
> oogroups.com>>]
> > > On Behalf Of Bill
> > > > Wu
> > > separate
> > > where
> > > > I can find it?
> > > > Thanks
> > > have
size(-Bt).
brad_boes
Brad Boes
Metalworks
than
> are taking place.
service
> effgroups@...
> Ephraim Feldman
the
> day.
> Thanks.
> Brad
> > > Brad Boes
> > > Metalworks
> > > > Thanks
> > > Of Ned
> > > section
> > > last
> > > > From:
> .com>>
> oogroups.com>>]
> > > On Behalf Of Bill
> > > > Wu
> > > separate
hint
> > > where
> > > > I can find it?
> > > > Thanks
> > > have
and
have
