AR Invoice Printing Error
We are getting error when printing certain AR Invoice. Any one can suggest
Program Ice.Services.Lib.RunTask when executing task 920920 raised an unexpected exception with the following message: RunTask:
System.Data.SqlTypes.SqlTypeException: SqlDateTime overflow. Must be between 1/1/1753 12:00:00 AM and 12/31/9999 11:59:59 PM.
at System.Data.SqlTypes.SqlDateTime.FromTimeSpan(TimeSpan value)
at System.Data.SqlTypes.SqlDateTime.FromDateTime(DateTime value)
at Microsoft.Data.SqlClient.MetaType.FromDateTime(DateTime dateTime, Byte cb)
at Microsoft.Data.SqlClient.TdsParser.WriteUnterminatedValue(Object value, MetaType type, Byte scale, Int32 actualLength, Int32 encodingByteSize, Int32 offset, TdsParserStateObject stateObj, Int32 paramSize, Boolean isDataFeed)
at Microsoft.Data.SqlClient.TdsParser.TDSExecuteRPCAddParameter(TdsParserStateObject stateObj, SqlParameter param, MetaType mt, Byte options, SqlCommand command, Boolean isAnonymous)
at Microsoft.Data.SqlClient.TdsParser.TdsExecuteRPC(SqlCommand cmd, IList1 rpcArray, Int32 timeout, Boolean inSchema, SqlNotificationRequest notificationRequest, TdsParserStateObject stateObj, Boolean isCommandProc, Boolean sync, TaskCompletionSource1 completion, Int32 startRpc, Int32 startParam)
at Microsoft.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean isAsync, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest)
at Microsoft.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry, String method)
at Microsoft.Data.SqlClient.SqlCommand.ExecuteNonQuery()
at Ice.Core.RptBase.DatabaseReportDataStorage.WriteRow(IDataSource dataSource, IRow row) in C:_releases\ICE\ICE5.1.100.10\Source\Server\Internal\Lib\TaskLib\RptBase\DatabaseReportDataStorage.cs:line 114
at Ice.Core.RptBase.ReportRowDataWriter.WriteRow(IRow row) in C:_releases\ICE\ICE5.1.100.10\Source\Server\Internal\Lib\TaskLib\RptBase\ReportRowDataWriter.cs:line 60
at Erp.Internal.AR.ARInvForm.DoCustomerCalculations() in C:_releases\ERP\ERP12.1.100.10\Source\Server\Internal\AR\ARInvForm\ARInvForm.cs:line 1975
at Erp.Internal.AR.ARInvForm.DoInvcHeadCalculations() in C:_releases\ERP\ERP12.1.100.10\Source\Server\Internal\AR\ARInvForm\ARInvForm.cs:line 3780
at Erp.Internal.AR.ARInvForm.RunProcess(Int64 instanceTaskNum, String outputFileName) in C:_releases\ERP\ERP12.1.100.10\Source\Server\Internal\AR\ARInvForm\ARInvForm.cs:line 1309
at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in C:_releases\ICE\ICE5.1.100.10\Source\Server\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 71
at Ice.Hosting.TaskCaller.ExecuteTask() in C:_releases\ICE\ICE5.1.100.10\Source\Server\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 62
at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in C:_releases\ICE\ICE5.1.100.0\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 57
at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in C:_releases\ICE\ICE5.1.100.0\Source\Server\Services\Lib\RunTask\RunTask.cs:line 349
It’s coming from a bad date on your invoice or a related record. Check for something like 01/01/0001. If you use uBAQs or paste updates from Excel you can get poorly formatted dates.
BadDates
I have checked the date and all looks good.
Have you looked at dates on all related records in the RDD? Any bad date can cause it to fail. There are a number of posts on here for the same error and where people found related records with incorrect dates.
Likely suspects: ShipDate in ShipHead…EntryDate and ReceiptDate in DropShipHead (if you do dropship orders). Have also seen that cause ASNs to go sideways.
we found the issue. The custom date column in customer value is 0205-08-24.
@chaddb gave you the solution not me LOL…but it’s good that you found the problem.
