Hello, I 've created a data directive that will sync a OrderRel UD field with its OrderHed UD field. So if i update the OrderHed UD field using a BAQ udpatable dashboard or the order entry screen it will also update the orders releases.
I’m using a function to update the OrderHed but I noticed it doesn’t update the releases as well. Are functions able to trigger data directives somehow or should I just sync to the releases directly in the function?
I was seeing the above behavior in 10.2.700 so I tried the same function in 2022.1 and the data directive was triggered. I guess chalk it up to a bug in the older version
