How did you handle doing step #3 “Added all the tables and relationships to the RDDv2”? What is the best way to do this? Did you do a side by side comparison between the custom RDDv1 with the new generic RDDv2?
When I did this, RDDv1 already had all the tables and relationships but is still erroring out in the system monitor with “query execution failed for dataset arform”. Do I need to drill down into the calc fields to compare also and manually add those or is that part of step #9?
What’s the difference between step #3 and Step #9? I can’t run it to get the Database GUID.
From what I’ve seen, it only gives you a generic error ‘query executionf ailed for the dataset ARForm’. The first error I fixed and added the specific field indicated in the task monitor but once I added that calc field, it then gave me the generic query execution error with no specific field?
Check the out of the box RDD, make sure the Calc field is present under the Calculated Fields tab for the target table. Be sure the RDDv2 has the Calc field as well.
