I am having some issues regarding the ARInvoiceSvc. I am trying to use the update method and I am getting a null reference exception.
RestClient client = new RestClient("https://server/epicor/api/v1/Erp.BO.ARInvoiceSvc/");
client.Authenticator = new NtlmAuthenticator();
var GetInvoice = new RestRequest("GetByID", Method.POST);
GetInvoice.AddHeader("Content-Type", "application/json");
var GetInvoiceParamObj = new JObject();
GetInvoiceParamObj.Add(new JProperty("invoiceNum", "660772"));
GetInvoice.AddParameter("ds", GetInvoiceParamObj, ParameterType.RequestBody);
IRestResponse GetInvoice_response = client.Execute(GetInvoice);
dynamic json = JValue.Parse(GetInvoice_response.Content);
json.returnObj.InvcHead[0].Company = "LP";
json.returnObj.InvcHead[0].ShortChar03 = "RG0014";
json.returnObj.InvcHead[0].ShortChar04 = "HAJOCA";
json.returnObj.InvcHead[0].ShortChar06 = "TEST2";
json.returnObj.InvcHead[0].CheckBox03 = false;
json.returnObj.InvcHead[0].CheckBox06 = false;
json.returnObj.InvcHead[0].RowMod = "U";
// strong typed instance
var jsonObject = new JObject();
dynamic ds = jsonObject;
ds.ds = json.returnObj;
//ds.Add(new JProperty("continueProcessingOnError", true));
//ds.Add(new JProperty("rollbackParentOnChildError", false));
var UpdateInvoiceTable = new RestRequest("Update", Method.POST);
UpdateInvoiceTable.AddHeader("Content-Type", "application/json");
UpdateInvoiceTable.AddParameter("ds", ds, ParameterType.RequestBody);
IRestResponse UpdateInvoiceTable_response = client.Execute(UpdateInvoiceTable);
if (UpdateInvoiceTable_response.ResponseStatus == ResponseStatus.Completed)
//return true;
else
//return false;
When I change this to use the UpdateExt Method (not entirely sure what the difference is, or its impact) It will work if I uncomment out the ds.add lines.
Although it works, it returns an exception message that I have no idea what it means.
BusinessObjectException
Message No.:1
Description: Tax Service records are committed. Update not allowed.
Program: Erp.Services.BO.ARInvoice.dll
Method: OnChangeofLineQty
Line Number: 23459
Column Number: 17
Any help would be appreciated.
EDIT:
Also, here is the stack trace if you need it.
System.NullReferenceException: Object reference not set to an instance of an object.
at Erp.Services.BO.ARInvoiceSvc.InvcHeadBeforeUpdate() in C:_Releases\ERP\UD10.2.300.3\Source\Server\Services\BO\ARInvoice\ARInvoice.cs:line 16208
at Ice.Services.Trace.TablesetProfilingCollector.DoRowEventTrace(String tableName, String methodName, Int32 rowCount, Action action) in c:_Releases\ICE\RL3.2.300.0\Source\Framework\Epicor.Ice\Services\TablesetProfilingCollector.cs:line 144
at Ice.TablesetBound3.UpdateRow(IceDataContext dataContext, Int32 tableNum, IIceTable table, IceRow updatedRow, IceRow originalRow, IColumnUncensor uncensor, TablesetProfilingCollector parentTraceCollector) in c:\_Releases\ICE\RL3.2.300.0\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 1263 at Ice.TablesetBound
3.WriteTable(IceDataContext dataContext, Int32 tableIndex, IIceTable table, TablesetProfilingCollector parentTraceCollector) in c:_Releases\ICE\RL3.2.300.0\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 974
at Ice.TablesetBound3.InnerUpdate[TUpdater](IceDataContext dataContext, TFullTableset tableset) in c:\_Releases\ICE\RL3.2.300.0\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 874 at Erp.Services.BO.ARInvoiceSvc.Update(ARInvoiceTableset& ds) in C:\_Releases\ERP\UD10.2.300.3\Source\Server\Services\BO\ARInvoice\ARInvoice.Designer.cs:line 4233 at Erp.Services.BO.ARInvoiceSvcFacade.Update(ARInvoiceTableset& ds) in C:\_Releases\ERP\UD10.2.300.3\Source\Server\Services\BO\ARInvoice\ARInvoiceSvcFacade.cs:line 10069 at Ice.Hosting.RestApi.OperationInvokeHelper.CallInvoker(IceDataContext dataContext, Type svcType, MethodInfo mi, Object[] inputs, Boolean isRoot) in c:\_Releases\ICE\RL3.2.300.0\Source\Framework\Epicor.Ice\Hosting\ServiceCaller\OperationInvokeHelper.cs:line 292 at Ice.Hosting.RestApi.OperationInvokeHelper.MakeServiceCall(IceDataContext dataContext, Type svcType, MethodInfo mi, Object[] parameters) in c:\_Releases\ICE\RL3.2.300.0\Source\Framework\Epicor.Ice\Hosting\ServiceCaller\OperationInvokeHelper.cs:line 248 at Ice.Hosting.RestApi.OperationInvokeHelper.CallCustomMethod(String serviceName, MethodInfo mi, Object[] paramList) in c:\_Releases\ICE\RL3.2.300.0\Source\Framework\Epicor.Ice\Hosting\ServiceCaller\OperationInvokeHelper.cs:line 212 at Epicor.RESTApi.DataSources.IceServiceCaller.CallCustomMethod(TypeMapping typeMapping, ContextInfo context, String methodName, Object inputObject) in c:\_Releases\ICE\RL3.2.300.0\Source\Framework\Epicor.RESTApi\DataSources\IceServiceCaller.cs:line 272 at Epicor.RESTApi.Controllers.CustomActionController.CustomMethod(Object input) in c:\_Releases\ICE\RL3.2.300.0\Source\Framework\Epicor.RESTApi\Controllers\CustomActionController.cs:line 25 at lambda_method(Closure , Object , Object[] ) at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass10.<GetExecutor>b__9(Object instance, Object[] methodParameters) at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ExecuteAsync(HttpControllerContext controllerContext, IDictionary
2 arguments, CancellationToken cancellationToken)
— End of stack trace from previous location where exception was thrown —
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at System.Web.Http.Controllers.ApiControllerActionInvoker.d__0.MoveNext()
at System.Web.Http.Filters.ActionFilterAttribute.d__5.MoveNext()
at System.Web.Http.Filters.ActionFilterAttribute.d__0.MoveNext()
at System.Web.Http.Controllers.ActionFilterResult.d__2.MoveNext()
at System.Web.Http.Filters.AuthorizationFilterAttribute.d__2.MoveNext()
at System.Web.Http.Dispatcher.HttpControllerDispatcher.d__1.MoveNext()
