ASCII Dump and Reload problem
Thanks Greg,
We are both on the same wave length at the same time except I had to delete the -rx at the end of the path to the shortcut. Don't know what made me think of it but now I am back in business.
Jill
--- In vantage@yahoogroups.com, "pcivantage" <vantagegroup@...> wrote:
> It sounds to me like you forgot the step where you add the "-rx" to the end of the pat on the shortcut. It will leave certain menus grayed out if you are not in the maintenance mode. Check that.
> Regards,
> George Hicks
> PCI
> --- In vantage@yahoogroups.com, Zac Jason Woodward <zac@> wrote:
> > If that is the case then the Username/password situation doesn't apply to you.
> > "Zac" Jason Woodward
> > Network Administrator
> > Intermountain Electronics, Inc.
> > O: 877-544-2291
> > M: 435-820-6515
> > F: 435-637-9601
> > www.ie-corp.com
> > Creating customer confidence through extraordinary service and experienced industry experts.
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of jillschoedel
> > Sent: Friday, October 07, 2011 11:16 AM
> > Subject: [Vantage] Re: ASCII Dump and Reload problem
> > Zac,
> > I did like you told me to and now I get an error box that says "** -P and -U startup parameters require _User file records. (709)". Do you know what this means?
> > Thanks,
> > Jill
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Zac Jason Woodward <zac@> wrote:
> > > Make sure you have connected to the database with a user that has appropriate permissions. When you connect to it you may need to click advanced options and put in the user name of sysprogress password sysprogress
> > > O: 877-544-2291
> > > M: 435-820-6515
> > > F: 435-637-9601
> > > www.ie-corp.com
> > > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of jillschoedel
> > > Sent: Friday, October 07, 2011 9:55 AM
> > > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > > Subject: [Vantage] ASCII Dump and Reload problem
> > > Hi,
> > > I am doing an ASCII Dump and Reload of our Test Database on a Test Server. I am on the step where I Dump the Data: (or Step #4.2 in the Epicor instructions) and the Table Contents (.d files) option in the OpenEdge Data Administration window under Admin -> Dump Data Definitions is grayed out and that is what I need to access next. Has anyone ever experienced this and knows how to fix it? It seems like it is a permissions thing. I am stuck in the middle of the Dump and Reload with nowhere to go. Can someone help me?
> > > Thanks,
> > > Jill Schoedel
> > > Network Systems Coordinator
> > > Metalworks
> > > (231)845-3148
Hi,
Jill Schoedel
Metalworks
(231)845-3148
O: 877-544-2291
M: 435-820-6515
F: 435-637-9601
www.ie-corp.com
Hi,
Jill Schoedel
Metalworks
(231)845-3148
Zac,
Jill
> O: 877-544-2291
> M: 435-820-6515
> F: 435-637-9601
> www.ie-corp.com
> Hi,
> Thanks,
> Jill Schoedel
> Metalworks
> (231)845-3148
O: 877-544-2291
M: 435-820-6515
F: 435-637-9601
www.ie-corp.com
Zac,
Jill
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Zac Jason Woodward <zac@...> wrote:
> O: 877-544-2291
> M: 435-820-6515
> F: 435-637-9601
> www.ie-corp.com
> Hi,
> Thanks,
> Jill Schoedel
> Metalworks
> (231)845-3148
32 bit or 64 bit progress?
O: 877-544-2291
M: 435-820-6515
F: 435-637-9601
www.ie-corp.com
Zac,
Jill
> O: 877-544-2291
> M: 435-820-6515
> F: 435-637-9601
> www.ie-corp.com
> Hi,
> Thanks,
> Jill Schoedel
> Metalworks
> (231)845-3148
Regards,
George Hicks
PCI
> O: 877-544-2291
> M: 435-820-6515
> F: 435-637-9601
> www.ie-corp.com
> Zac,
> Thanks,
> Jill
> > O: 877-544-2291
> > M: 435-820-6515
> > F: 435-637-9601
> > www.ie-corp.com
> > Hi,
> > Thanks,
> > Jill Schoedel
> > Metalworks
> > (231)845-3148
Zac,
It is 64 bit progress. But I just figured it out. The icon for the Data Administration program had in it's properties a "-rx" at the end of it. I cleared that out and now it works like a charm. Thanks for trying to help me. It was much appreciated:>)
Jill
> O: 877-544-2291
> M: 435-820-6515
> F: 435-637-9601
> www.ie-corp.com
> Zac,
> Thanks,
> Jill
> > O: 877-544-2291
> > M: 435-820-6515
> > F: 435-637-9601
> > www.ie-corp.com
> > Hi,
> > Thanks,
> > Jill Schoedel
> > Metalworks
> > (231)845-3148
