I am trying to figure out why ASM 0 in Job Entry shows the approved revision for the part we are pretend manufacturing (in our Pilot environment), but the Materials didn’t come thru from what was on that approved revision.
Since Material didn’t show we received error “No Assembly or Materials to Mass Issue for Job ### and Assembly No 0.”
It makes sense that we received this error because there were not materials shown on the job, but why didn’t it pull that information from the BOM and why does it show the approved revision in the Assembly card?
The revision has been approved, and the revision shows Operations and Materials in Method Tracker. The Materials in the Method Tracker are all Assemblies that have two or more parts to create that material.
However, when we create a Sales Order and create a job from that sales order and select Create Job, Get Details, Get Schedule and Release the Job does not show any material and rather shows the material as an assembly under its related operation.
Ah, yes they are set as Pull as Assembly and View as Assembly.
So if those check boxes are set then it seems that when we are issuing material in MES Data Collection, it doesn’t show any material to issue…even though there are materials.
