tgwinn
(Tim Gwinn)
July 18, 2025, 2:43pm
1
In BPM custom code I need to write to a UD table, UD01.
Following this comment , I have this code chunk:
using(var UD01svc = Ice.Assemblies.ServiceRenderer.GetService<UD01SvcContract>(Db))
UD01Tableset ds = new UD01Tableset();
UD01svc.GetaNewUD01(ref ds);
ds.UD01[0].Key1 ="XX";
ds.UD01[0].Key2 = "YY";
ds.UD01[0].Key3 = "ZZ";
UD01svc.Update(ref ds);
And in Assemblys, I added:
Ice.Contracts.BO.UD01
But when I check syntax I get:
CS0246 The type or namespace name ‘UD01SvcContract’ could not be found (are you missing a using directive or an assembly reference?)
Is there an additional assembly I need or something added under Usings?
WHy are you calling get a new UD02 if you are updating UD01?
tgwinn
(Tim Gwinn)
July 18, 2025, 2:50pm
3
That is a typo. The original code chunk I copied was for UD02. Fixing that does not resolve the error, though.
tgwinn:
UD01SvcContract
You need the appropriate using statement. Something like
Using Ice.Contracts.XYZ
tgwinn
(Tim Gwinn)
July 18, 2025, 3:10pm
5
I should note that this is a Standard Data Directive.
I tried add Using statements (“using Ice.Contracts.BO;” or “using Ice.Contracts.BO.UD01;”) but neither resolved the issue.
I just saw this comment on another post, and when I copied the code chunk to a Method Directive with just the same Assembly added, then Check Syntax was OK.
If this can’t be done from a DD, this is going to be a major problem. But the DD still has the Invoke BO Method widget, so I am assuming it can be done.
tgwinn
(Tim Gwinn)
July 18, 2025, 3:35pm
6
Found this comment , with some different syntax, which does pass Check Syntax:
Ice.Contracts.UD01SvcContract UD01svc = Ice.Assemblies.ServiceRenderer.GetService<Ice.Contracts.UD01SvcContract>(Db);
In Assemblies:
I still need to test and see if it actually works, though.
EDIT: Confirmed that this works as expected.
