Hi all,
Our company is in the process of implementing Epicor Kinetic ERP (SaaS). I’m evaluating whether to go ahead with Epicor’s Product Configurator module. One of our aims is to standardise our product BOMs, so that they can be generated (at least in part) at Quote/Order stage.
Currently, most of our Assembly BOMs are bespoke and created per project. However, within these assemblies, there are some sub-assemblies and parts that are standard, based on type of product etc. We therefore want the Configurator to create partial BOMs containing these standard parts, with dummy records for the ‘bespoke’ parts that need to be designed by our Engineering team.
The alternative we demo’d was Driveworks, which also has a Configurator module. However, using Epicor Configurator for the front-end forms means that our Sales people can use one system for quoting configured products and ‘new designs’.
For those of you using the Epicor Product Configurator (or have integrated with Driveworks configurators):
- What ‘gotchas’ have you come across in setup/usage?
- Does the tool have any limitations for your needs?
Any advice/experience you can share would be fantastic - thanks!
