I am creating a program that prompts for a start and end date. It then retrieves all orders that are within the user entered range and dumps the results to a .csv file.
Question is if I compile this into a .r file. How can I attach it to a menu and have it still prompt the user for the required criteria. What would I need to revise on this program in order to do this and how to attach to menu? We are running Vantage 6.1 THANKS.
define variable varstartdate as date label "Start Order Date" no-undo.
define variable varenddate as date label "End Due Date" no-undo.
repeat:
update varstartdate
varenddate.
leave.
end.
output to v:\a\out.csv.
export delimiter "," "OrderNum" "CustNum" "PONum" "OrderDate".
for each orderhed where orderhed.company = "DD-1" and
orderhed.orderdate >= varstartdate and
orderhed.orderdate <= varenddate no-lock:
orderhed.ordernum
orderhed.custnum
orderhed.ponum
orderhed.orderdate.
end.
output close.
repeat:
update varstartdate
varenddate.
leave.
end.
orderhed.ordernum
orderhed.custnum
orderhed.ponum
orderhed.orderdate.
end.
output close.
