"Attempted to perform an unauthorized operation" error: client side function
Application Error
Exception caught in: Epicor.Ice.Lib.RestClient
## Error Detail ##
##!Message:##! Attempted to perform an unauthorized operation.
##!Program:##! Epicor.Ice.Lib.RestClient.dll
##!Method:##! MoveNext
## Client Stack Trace ##
   at Ice.Lib.RestClient.ResilientCaller.<InnerPostAsyncWithErrorHandling>d__5.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   at Ice.Lib.RestClient.ResilientCaller.<PostAsyncWithErrorHandling>d__4.MoveNext()
   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   at Ice.Lib.RestClient.AsyncToSyncHelper.DoSynchronous[TResult](Task`1 task)
   at Ice.Lib.RestClient.RestClient.Ice.Lib.RestClient.IRestFunctionCaller.Post(String library, String function, RestContent content, Boolean published)
   at Script.btnSelect_Click(Object sender, EventArgs args)
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at Infragistics.Win.Misc.UltraButtonBase.OnClick(EventArgs e)
   at Ice.Lib.Framework.EpiButton.OnClick(EventArgs e)
   at Infragistics.Win.Misc.UltraButton.OnMouseUp(MouseEventArgs e)
   at Ice.Lib.Framework.EpiButton.OnMouseUp(MouseEventArgs e)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Visual Studio:
System.UnauthorizedAccessException
  HResult=0x80070005
  Message=Attempted to perform an unauthorized operation.
  Source=Epicor.Ice.Lib.RestClient
  StackTrace:
   at Script.btnSelect_Click(Object sender, EventArgs args) in c:\ProgramData\Epicor\dev01-808\3.2.600.0\JRF\CustomDLLs\App.Quotes_Parts.MainController.EP.Customization.Reverse Search.CustomCode.0.cs:line 386
  This exception was originally thrown at this call stack:
    [External Code]
    Script.btnSelect_Click(object, System.EventArgs) in App.Quotes_Parts.MainController.EP.Customization.Reverse Search.CustomCode.0.cs
    [External Code]
Is is working or not working on the same machine or different?
is the same sysconfig with thes same binding is used?
Is it possible that you run client with and without Run as administrator for this case?
It is not working on the same machine with different users. It does NOT fail for all users, just some. I also tried it with different users on different machines and same result
It is the same sysconfig/client and same bindings for each of these tests. The only difference is if I run as a different (known to fail) user, it fails.
The clients do not run as administrators, but I will verify this test as well.
We do use Windows binding btw, not sure it that’s helpful
Is it possible that there is no data for these users? For example, no records because of Territory security?
That is an interesting theory. I would think it would also fail at the REST API level using that users credentials if this were the case however, but I am not seeing that. Let me explore that
Well, i think this is the problem, RestClient uses Windows auth frpm session AFAIR, so not sure how are you trying to make it work with different users on the same machine
This doesn’t explain why it wouldn’t work for that users machine however, I would think?
So I first hear about this from the user who is using their machine (and logged in as such), so I would think the windows session would be totally kosher.
Only in the testing scenario am I running Epicor as the different users, but I am indeed able to replicate the failure by simply having those ā€œproblemā€ users attempt the test on their machine
try to set username binding in sysconfig for test
Ok let me attempt…
UsernameWindowsChannel or UsernameSSLChannel?
Wheteve you have free on the server.
I guess tcp is already used for Windows binding, so http will be fine for try
Shoot, it seems neither one is letting me in. Do I need to establish the binding on the EAC, I’m guessing?
THis is not production server, right :slight_smile: ?
yes, you use either EAC or just set it directly in web.config
haha correct. I’d like to set it in the web config so I can easily go back :wink:
Ok let me set it there…
search for protocolMapping in web.config
1 binding per protocol
Should I do the HttpsOffloadBinaryUserNameChannel or the other one?
NVM I’m an idiot, disregard. the first is http
whe do you have now? net.tcp only? or https as well?
In any case, dont use Offload , it is only for SSL offloading on some indtermediary host, lke ARR and F5
so I would go with HttpsBinaryUsernameChannel
I assume you have https cert already installed as you use functions
add
<add scheme="https" binding="customBinding" bindingConfiguration="HttpsBinaryUsernameChannel" />
after <remove scheme="https" />
Ok I changed the web config and recycled IIS app pool for that. I should change my client config to not use Windows, but instead use HttpsBinaryWindowsChannel
