Bump...
--- In vantage@yahoogroups.com, "Michael" <mjdelawter@...> wrote:
> I am hitting a wall while trying to set up ODBC on Vantage 6.10.528.
> I have the kit from Epicor for ver 6.1 and have performed the fix
> that truncates the length of the index descriptions - apparently no
> problem there.
> When I go to the second step that is supposed to create the
> sysprogress user id and password by using odbcuser61.r, I receive a
> message in the progress window that states "you are only allowed to
> change your own password (711) Press Spacebar to continue".
> After this, when you attempt to open the Progress Data
Administration
> screen using startup procedure gui/_admin.r, I am required to first
> log in, and the user id / password sysprogress is not working. I
> have also tried odbcuser, just in case the instructions were wrong
or
> out of date (yeah, like that never happens).
> Does anyone know what could be causing the set up of sysprogress to
> fail and if so, what a workaround might be for it. Just so you
know,
> contacting tech support is not an option as we are not currently
> paying for it.
> TIA,
> Michael DeLawter
> ISO/IT Manager
> Stone City Products
