Auto Numbering Fixed Assets
Welcome to the community @shopkins46.
Refer to this post here.
Auto Numbering - Customer ID - #9 by changchai The pdf Tim posted gives instructions on how to do this. But instead of doing on the GetNewCustomer, use the FAsset.GetNewFAsset and FAsset.Update BOs.
Give it a try and let us know how you get on.
What version of 10 are you on?
You mentioned you are fairly new so here is a list of resources you might find useful:
  • Epicor Epicweb Documentation The go to place to get PDF versions of release notes, user guides, customisation guides business object help files, installation guides broken down by version. Tip here is look for the major releases, they are the ones with the most documents against them.
  • Online help is exceptional and most recent versions have pdf copies of the application help and customisation guides. Note there help from the Kinetic UI is different to the Classic and if you want information on Application Studio then you need to be using the Kinetic UI. Just search for Application Studio, there is all sorts of goodness there.
There are a myriad of useful tools that will help you with your development journey also:
There are probably others that I am unaware of as well.
Thanks to all those that have taken the time to develop and contribute those projects.
I hope you find the information useful.
