Hello everyone,
I’ve been doing some auto-printing lately pack lists, and after a bit of messing around, it got me to thinking about the report parameters. Some of the names are bit undercipherable, and in some instances it’s just a process of trial and error to work them out.
For example
Parameter Name
Parameter Type
Action
ParameterLabel
IsCriteria
PackNum
System.Int32
0
PackNum
FALSE
PrintingOptions
System.String
S
PrintingOptions
FALSE
AssignLegalNumber
System.Boolean
False
AssignLegalNumber
FALSE
EnableAssignLegalNumber
System.Boolean
False
FALSE
DCHdrList
System.String
DCHdrList
FALSE
PackNumList
System.String
callContextBpmData.Character01
PackNumList
FALSE
StyleNumExt
System.Int32
2
StyleNumExt
FALSE
EnableIncludePCID
System.Boolean
False
EnableIncludePCID
FALSE
IncludePCID
System.Boolean
False
IncludePCID
FALSE
DocCopyNum
System.String
DocCopyNum
FALSE
DraftMode
System.Boolean
False
DraftMode
FALSE
ArchiveCode
System.Int32
0
ArchiveCode
FALSE
DateFormat
System.String
d/mm/yyyy
DateFormat
FALSE
NumericFormat
System.String
NumericFormat
FALSE
ProcessCompany
System.String
ProcessCompany
FALSE
ProcessSystemCode
System.String
ProcessSystemCode
FALSE
SSRSRenderFormat
System.String
SSRSRenderFormat
FALSE
UIXml
System.String
UIXml
FALSE
PrintReportParameters
System.Boolean
False
FALSE
SSRSEnableRouting
System.Boolean
false
SSRSEnableRouting
FALSE
DesignMode
System.Boolean
False
DesignMode
FALSE
Things like UIXml I’m assuming that’s got something do to with the actual parameters form? Is there a document or is it in the data dictionary perhaps that explains some of the less than decipherable parameters for all reports?
Sorry, I’ve never heard of anything like that.
Guessing this is one of those areas that might be deemed a little too obscure to warrant official documentation?
Just curious… can you explain what you are working on, want to do with the parameters?
Basically, I was creating a cascading report print scenario. We have a solution that allows the users to collect all different types of shipments together, allocate them to a truck/driver and print a list of the “Run” to go and Pickup/Drop off, be it an RMA pickup, subcontract drop off, Transfer Order, or Customer shipment.
Users wanted to print all the related pack slips after printing the runsheet, which makes sense. We don’t have EMW or POD lite, as we are pretty old school and love to print everything out.
So I was working my way through using a mix of auto-print and print routing to acheive this. Where my curiosity got the better of me was I was looking at the auto-print parameters for the customer shipment pack slip. Some of the parameters in the Autoprint appear on the parameters form others don’t, and there really was not clear explanation anywhere I could find, which prompted me to ask the question if there was such a document that outlined each of these fields, on a per report basis, sort of like the BOmethods helpfile. I think I did look at the data dictionary, but I recall it was not that helpful, but happy to be told different.
It’s these sort of segways that can chew up a heap of time, if you could just go to a document, and it was all mapped out it would really helpful.
