There are some arbitrary limitations in terms of what you can do with
MES.
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
Picometrix
bspolarich@... ~ 734-864-5618 ~
www.advancedphotonix.com
Of mjhoney71
Sent: Tuesday, January 27, 2009 2:27 PM
Subject: [Vantage] Re: auto-refresh php based dashboard
The baq is marked as shared but the user running the dashboard is not
the same user that created the baq. We don't get the mentioned error
unless we try using the dashboard in MES. Could there be some type
of limitation with MES on the tables that can be queried?
Marc
"Brian W. Spolarich "
<bspolarich@...> wrote:
Behalf
40yahoogroups.com> ] On
MES.
Picometrix
Of mjhoney71
Marc
>Photonix /
> Are you logged in using the same account? Is the BAQ that the
> dashboard is using marked as Shared?
> Picometrix[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
Behalf
> Of mjhoney71<mailto:vantage%40yahoogroups.com> ,
> Sent: Tuesday, January 27, 2009 1:06 PM
> Thank you very much, this approach worked very well. I have another
> issue I was wondering if you could help me with. When I try to use
> this dashboard in the Vantage MES I get an error "Invalid query:
> where (Company='Argo-MI' and ()) and (IsShared = yes or
> DCDUserID='timeclock') and (Approved=yes)". What might be causing
> this problem? I don't get this error when using the dashboard in a
> full Vantage client.
> Thanks,
> Marc
> "Brian W. Spolarich "deleted
> <bspolarich@> wrote:
> > Yes. The trick is that you need to have the dashboard tab get
> its URL
> > from a BAQ. Here's how I did it.
> > 1. Write a BAQ that returns a single calculated field whose
> value
> > is the URL you want to use. I just pick the Company table for my
> base
> > table, even though I don't select any fields from it. The Progress
> > syntax for a string is to enclose it in double quotes. E.g.
> > http://intranet.mycompany.com/foo.aspx.
> > 2. Add that query to your dashboard. Publish the URL field
> from
> > the query.
> > 3. Add a URL view to your dashboard. Subscribe the URL view
> to
> > use the query's published field.
> > 4. Now it will auto-populate as you expect. You can drag the
> > Dashboard Grid View to the bottom to minimize you since you won't
> care
> > to show it on this tab but I would get runtime errors if I
> it.<mailto:vantage%40yahoogroups.com>
> > That's it. Kind of a kluge but probably explainable given the
> > Dashboard program's event model.
> Photonix /
> > Picometrix
> > bspolarich@ ~ 734-864-5618 ~
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com><mailto:vantage%
> Behalf<mailto:vantage%40yahoogroups.com>
> > Of mjhoney71
> > Sent: Monday, January 26, 2009 3:45 PM
> > Subject: [Vantage] auto-refresh php based dashboardrun
> > I have a php script that I call via a url in a dashboard to show
> > employees how many hours they have clocked for the week. When I
> > the dashboard from inside a Vantage client it just brings up a[Non-text portions of this message have been removed]
> blank
> > page with a mini IE toolbar. I have to click the home icon on the
> > toolbar to get the data to populate. Is there a way to call this
> url
> > so it will auto-update?
> > TIA,
> > Marc
