Yep, tried it after I sent my last message and decided to modify the shortcut for MES instead and leave the Vantage shortcut unchanged.
Just added /config=meslive.mfgsys and then made the changes you suggested below.
Done Deal, Thanks !
Neil
Done Deal, Thanks !
Neil
--- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@...> wrote:
> No that's the way to do it. You'll want to have different Windows shortcuts that invoke Vantage with different config files.
> -bws
> Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
> Â Â Â Â bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of too_much_hg
> Sent: Tuesday, May 12, 2009 4:50 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: AutoMagic Login for MES stations
> Brian,
> That is exactly what I was looking for ! Works great !
> Now I have a new and un-anticipated problem, how can I prevent this single sign on when starting a "Normal" Vantage session on these thin clients. (used by supervisors occasionaly)
> I think I might be able to point to a different .mfgsys file ?
> Would I add the parameter CONFIG=supervisor.mfgsys to the shortcut ?
> Maybe there is a better way than that ?
> Thanks, Neil
> --- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@> wrote:
> > I think it uses the Windows userid.
> > Why not turn on Single Signon and just use the Windows authenticated credentials to log onto Vantage?
> > Basically you just need to pick the Windows userid and domain that you want to associate with the Vantage userid, and then turn on single signon in the .mfgsys file:
> > <userSettings>
> > <!-- provide values for UserID and Password to enable auto-login -->
> > <UserID value="" />
> > <Password value="" />
> > <SingleSignOn value="true" bool="" />
> > Then you'll log onto Vantage as the Vantage user that has the Windows user account configured of the Windows user you're logged on as.
> > -bws
> > Â Â Â Â bspolarich@ ~ 734-864-5618 ~ www.advancedphotonix.com
> > Sent: Tuesday, May 12, 2009 3:55 PM
> > Subject: [Vantage] AutoMagic Login for MES stations
> > We have 40 MES stations setup with each one using a unique login to start the Terminal Service Session.
> > I have found the way to modify the .mfgsys file to allow automatic login as long as I type in the login and password into the .mfgsys file.
> > ------------ begin snip from .mfgsys file ---------------
> > <userSettings>
> > <UserID value="LOGIN-NAME" />
> > <Password value="LOGIN-NAME" />
> > ------------ end snip from .mfgsys file ---------------
> > I would like to pass the login name to both the Login AND Password fields for the logon dialog box.
> > What can I put in the .mfgsys file to accomplish this ?
> > I tried the usual suspects "%logon%", "$logname$", what environment variable does Vantage use when building the logon box ?
> > Vantage apparently knows the logon name because it already populates the Login portion leaving the Password blank.
> > TIA - Neil
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> > (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
