For anyone getting the "Unable to understand after DECLARE" error message,
download the registry fix that I've made from the files area at eGroups.
http://www.egroups.com/files/vantage/ The file is ivpro14 for 3.5.reg.
This fix will only work with the Merant driver version 3.5 or higher. I
have only tested it with version 8, but I believe it will work with version
7 of Crystal reports. It is similar to the one that Seagate Software sends
to users with connection issues, I've just modified it to work better with
the Merant driver. This registry file will update the registry and tell
Crystal Reports how to properly format the SQL statements so that the Merant
driver can pass them off to Progress properly.
Hope this helps,
Ted Kitch
ted@...
it@... [mailto:
it@...]
Sent: Tuesday, January 23, 2001 3:29 AM
To:
vantage@egroups.com
Subject: [Vantage] Re: Automatic reports via email
Troy,
I think you are right. We upgraded from 6 to 8, and it was a big leap. The
product is now much more reliable and the Web Component Server is a
brilliant piece of technology. Luckily for me I had just purchased a couple
of NT Workstations, so I grabbed one for myself and set up an intranet on
it, and we now have our ODBC reports shared on that, no hassle.
The "declare" bug still crops up on very complex reports, but is better than
in 6.
Regarding your drawback of having to save the Vantage-generated reports as
version 7, try this:
- Make a backup of the following files from the Epicor/Vantage/Dll folder:
crpe32.dll
crpaig32.dll
crpaig80.dll (if it is present)
- Find the following files on your Crystal Reports 8 development machine,
and copy them into the Epicor/Vantage/Dll folder:
crpe32.dll
crpaig32.dll
crpaig80.dll
That will update the Crystal Reports Engine and related dll's that Vantage
uses, so that it writes version 8 reports and is compatible with any v8-only
features (e.g. Basic Syntax).
If you do have any problems, needless to say, put your old files back, but
I'd be glad to help if I can.
Having said that, it should work fine. I have no problems with it here.
On another point, yeah, I do sometimes read the manuals, but they're
frustrating things, and I don't think the Crystal one is a very good one.
As with most software, you get a better understanding of it by having a
quick browse of it's features (which should give you an idea of how you can
best use it) and getting stuck in.
Anton Wilson,
Systems Analyst,
Deanestor Healthcare
Message: 15
Date: Mon, 22 Jan 2001 12:08:50 -0800
tfunte@...>
Subject: Re: Automatic reports via email
I am using version 8. I am not aware if the PDF export is available for
version 7.
Version 8 is far superior to 7 in my honest opinion. It does run faster for
some reports than 7 did, primarily because you get to see the first page as
soon as it is compiled, and you can begin navigating that page while it
continues working on the next 200 pages.
Also, they have fixed SOME of the linking bugs that happen - such as the
DECLARE bug (where you had to delete the parenthesis in the SQL statement).
Also, you can have one report running in designer... And open a whole other
session of Crystal in another window and start working on another report
while the first in crunching away. A great time saver.
Also, with the Web Component, you have a powerful way of distributing
reports without needing the compiled reports and ODBC license on each
machine that uses the reports. (Only drawback - you need another piece of
hardware. But if we had had this before we pruchased 11 ODBC licenses at $99
each, we could have bought a nice machine with NT to run the Web Component
and distribute reports.)
Main drawback of version 8 is related to Progress itself... You need to save
any Crystal reports that Vantage itself initiates by saving as a version 7
report. It's only a drawback because you have to specify version 7
everytime you save, or it will be a version 8 report.
Install version 8 and start going. The learning curve was very short. A
quick glance through new features section of the manual will get you onto
the new things fairly quickly. Does anyone read the manuals out there?
Troy Funte
Liberty Electronics
eGroups Sponsor
http://rd.yahoo.com/M=168002.1291681.2888959.2/D=egroupmail/S=1700007183:N/
A=564919/*
http://www.columbiahouse.com/gateway?token=7406> Get 3 CDs for
ONLY $9.99!
Get 3 CDs for ONLY $9.99!
http://us.adserver.yahoo.com/l?M=168002.1291681.2888959.2/D=egroupmail/S=17
00007183:N/A=564919/rand=136095149>
To unsubscribe from this group, send an email to:
vantage-unsubscribe@egroups.com
