Greetings Dear, please i need help to upload document pdf from directory to menu or module attachment using customization not bpm, if there is a way please let me know, thank you.
regards, ahmad itani
Since it is the header, you might be able to use this
https://www.epiusers.help/t/code-from-meug-presentation-on-5-20-2020-customization-tips-and-tricks/67376
But as I discovered, this approach doesn’t work with lines/releases.
Ref Add attachment single code line - edvCurrAsm in Job entry...ugh?
Also, if you do a search of the site there are several good topics on adding attachments thru code.
You are my hero, Thank you very much you saved my life, i was looking all over the internet for this code.
Regards, Ahmad Itani
