Automation Studio and refreshing connected Kinetic test environment
I need to refresh the test Kinetic environment that is connected to my test instance of Automation Studio. When I restore my production database to test and make all my normal adjustments, anyone know the correct process to get my test instance of Automation Studio connected back to the test instance of Kinetic?
There should be the ability to reconnect your instance in integration.epicor.com, but that currently is not working for us (active support case).
If you make a backup of your settings before you restore from production, you can simply reapply them. The settings you need will start with IP in the SysConfig table.
SELECT * FROM ice.sysconfig where key1 like 'IP%'
