Yep.
Everything in the config file looks correct. Only the company that had the domain migration is down, the other companies are fine (and we all use the same config file).
I swear @josecgomez just went over AD auth tokens in azure on a different post related to someone coding an API call or something⦠does it relate to this too maybe. I will try and find the post.
Do you have to create something new here?
Delete everything here @aosemwengie1
%AppData%\epicor\AzureAD
On the client. I suspect if you had an old token in there it is trying to use the token with the wrong key.
I went back and read, you said domain migrationā¦
Did you create a new Azure AD App after the migration and update the Azure Settings within Epicor as well as in the SysConfig File?
Iām not sure what āDomain Migrationā means but it smells as something that would require a new Azure App be created and re-configired.
If the azure app needed to be recreated why would the browser login still work?
Thatās a good point, did you try deleteting that file?
Trying it now
Omg it worked. Thank you!!!
Has Epicor always used this folder even in 10?
Yes as far back as when they introduced Azure Login whenever that was.
My guess would be that the browser does not look at that file⦠itās for a Smart Client configuration. Browser-based doesnāt require anything at all on the local file system, just the browser itself.
Just a guess.
That was the point I was making lol. That the problem HAD to be a local file, because otherwise the browser login would also be broken. I just phrased it as a question.
