AzureAD China
Hi~
Perhaps anyone has encountered similar problems?
Our customer is using Azure China. When we enable AzureAD authentication in Epicor, click Connect to Application Server from the Epicor Administrator Console and we receive the following error: Tenant ‘xxxx’ not found. Check to make sure you have the correct tenant ID and are signing into the correct cloud. Checkwith your subscription administrator, this may happen if there are no active subscriptions for the tenant…
We are sure that Tenant ID is correct, we suspect that this problem is not related to Azure Global, may I ask who has encountered similar problems how to solve? Thank you very much
