Michael,
Try ending your if after the not available.
and also end the else statement at the end.
I would also assign the email "to" with an email address within the .p to be
safe.
If I am not mistaken, your logic is missing the second if statement unless
the Part table is not available, the opposite of what you are looking for.
Also, I don't believe you need to call out the full name of Mfgsys.Part,
just Part should do, the database is assumed.
I suspect this will fix most of the problems.
For instance:
{ud/GlbAlert.i &TableName = "RcvDtl"}
FIND Part WHERE Part.PartNum = RcvDtl.PartNum
NO-LOCK NO-ERROR.
IF NOT AVAILABLE Part THEN RETURN "Cancel Send":U.
END.
IF (Part.Mtl-AnalysisCode = "ECN":U) THEN DO:
ASSIGN Email-Subject = "ECN Critical Item"
Email-To = "insert the email address here".
END.
ELSE RETURN "Cancel Send":U.
END.
Good luck,
Aaron Hoyt
Vantage Plastics
Sent: Monday, February 21, 2005 10:17 AM
Subject: [Vantage] BAM Class 101
OK folks, I need some help with my first BAM. It is simple, but I
can't get it to work. What I want is to send an alert when a part
is received that has a specific Material Analysis Code in the Part
table. The code in question is "ECN". (We are trying to improve
part of our ECN process.)
What I have written (copying from the samples) is:
FIND Mfgsys.Part WHERE Mfgsys.Part.PartNum = Mfgsys.RcvDtl.PartNum
NO-LOCK NO-ERROR.
IF NOT AVAILABLE Mfgsys.Part THEN RETURN "Cancel Send":U.
IF (Mfgsys.Part.Mtl-AnalysisCode = "ECN":U) THEN DO:
ASSIGN Email-Subject = "ECN Critical Item".
END.
I have worked on this until I no longer get any errors, but I still
don't receive the email. Any suggestions for a Progress newbie?
Perhaps the code is OK, but I am doing something wrong on the BAM.
Michael Randolph
Purchasing Manager
American Magnetics, Inc.
safe.
For instance:
NO-LOCK NO-ERROR.
END.
END.
END.
Good luck,
Aaron Hoyt
Vantage Plastics
NO-LOCK NO-ERROR.
END.
Michael Randolph
Purchasing Manager
