BAM Export p file
Larry,
Same .p file, in the BAM add all the fields to the list that you want to
trigger the export.
You will not need an if statement in the .p, just use the fields that you
call out in the BAM and when one of them changes, the code will be called,
if anything else changes, no .p will be called.
Good luck,
Aaron Hoyt
Vantage Plastics
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of Larry Barriere
Sent: Friday, January 13, 2006 9:29 AM
To: Vantage Group
Subject: [Vantage] BAM Export p file
I would like to create a p file that will export a customer file only if
there is change in any of the customer table.
Example 1
If a new customer is added I would like to export a cvs file of that
customer only.
Example 2
If someone change the address, city or state. I would like to export a cvs
file for that customer.
I know I could create the p file if only one of the field is change but I
need to write it so that if any field within the customer table is change I
want it to export the customer.
Thank you in advanced
Larry Barriere
barrier@...
signature
Yahoo! Photos – Showcase holiday pictures in hardcover
Photo Books. You design it and weÂ’ll bind it!
Yahoo! Groups Links
I would like to create a p file that will export a customer file only if there is change in any of the customer table.
Example 1
If a new customer is added I would like to export a cvs file of that customer only.
Example 2
If someone change the address, city or state. I would like to export a cvs file for that customer.
I know I could create the p file if only one of the field is change but I need to write it so that if any field within the customer table is change I want it to export the customer.
Larry Barriere
barrier@...
signature
