Chris,
For some reason my post hasn't come through so I will try again...
If the calculated field is not a summarized field and is named 'MyCalcField' try this:
Table.Field1 - Table.Field2 - MyCalcField
Don't worry about the parenthesis around the calculated field or about the 'table.name' syntax.
Ross
Ross
--- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@...> wrote:
> My First calculated field is Total(Table.Field1)
> I want my second one to be Table.Field3 - Table.Field2 - Calculated.Above
> Thanks.
> From: Karen Schoenung <kschoenung@...>
> To: vantage@yahoogroups.com
> Sent: Tue, 24 November, 2009 14:48:10
> Subject: RE: [Vantage] BAQ Calculated field referencing another calculated field
> ÂÂ
> If your formula for Calculated.Field1 is field1+ field2…
> Your next calculated field formula should be
> Table.Field1 - Table.Field2 - (field1 + field2)
> Highlighted part is just copied from the original formula and put within parenthesis for a new calculated field…
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of Chris Thompson
> Sent: Tuesday, November 24, 2009 8:43 AM
> To: vantage@yahoogroups .com
> Subject: Re: [Vantage] BAQ Calculated field referencing another calculated field
> Hi Karen,
> Not entirely sure what you meanaboyut the in parenthesis.
> Thanks.
> ____________ _________ _________ __
> From: Karen Schoenung <kschoenung@fisher- barton.com <mailto:kschoenung% 40fisher- barton.com> >
> To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
> Sent: Tue, 24 November, 2009 14:29:46
> Table.Field1 - Table.Field2 - (formula for Calculated.Field1 in
> parenthesis) ?
> Table.Field1 - Table.Field2 - (formula for Total(Table. Field3) in
> parenthesis) ?
> For this - If it is null I want it to display 0.00 but if it has
> something in it I want it to display the actual figure. - I have seen a
> previous thread suggest compare your field with a known empty field...
> If your field = known empty field then 0.00
> Else actual.figure
> From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On Behalf
> Of Chris Thompson
> Sent: Tuesday, November 24, 2009 4:38 AM
> calculated field
> Please can anyone send an example of your calculated field where you are
> referencing another calculated field?
> Has anyone managed to reference a calculated 'total(xyz)' field within
> Im trying to
> Table.Field1 - Table.Field2 - Calculated.Field1
> Another option would be ...
> Table.Field1 - Table.Field2 - Total(Table. Field3)
> Any help would be appreciated.
> In addition, if a field is null, how do I create a calculated field to
> check if the field is null?
> If it is null I want it to display 0.00 but if it has something in it I
> Again, any help would be appreciated.
> Thanks,
> CHRIS THOMPSON
> From: Linda Lowney <llowney@pridesigns . com
> <mailto:llowney% 40pridesigns. com> >
> Sent: Mon, 26 October, 2009 14:17:00
> calculated field
> Thanks Steve. I'll give that a try next time I have to reference more
> than one calculated field.
> Linda
> Behalf
> Of Steve_E
> Sent: Monday, October 26, 2009 9:39 AM
> calculated field
> I am on version 408A and have referenced more that on calculation field.
> I
> have noticed that there may be a memory leek problem with the baq.
> Sometimes when referencing more than one you have to exit out of the baq
> editing screen re enter and re open the baq to get the calculation to
> work.
> Steve
> -----Original Message-----
> From: Linda Lowney [mailto:llowney@ pridesigns. com
> <mailto:llowney% 40pridesigns. com> ]
> Sent: October 26, 2009 7:51 AM
> calculated
> field
> We are on 8.03.407 and I was able to reference one calculated field, but
> if I tried to reference more than one in a calculation it failed.
> From: vantage@yahoogroups <mailto:vantage% 40yahoogroups. com> .com
> [mailto:vantage@ yahoogroups <mailto:vantage% 40yahoogroups. com> .com]
> On
> Behalf
> Of Alex Fiedler
> Sent: Sunday, October 25, 2009 11:54 PM
> To: vantage@yahoogroups <mailto:vantage% 40yahoogroups. com> .com
> Subject: [Vantage] BAQ Calculated field referencing another calculated
> field
> The Vantage online help section on BAQ calculated fields clearly states
> that "An expression can also reference another calculated field."
> Exactly how this is done is not mentioned. Has anyone been able to
> create a calculated column in a BAQ which refers to another calculated
> column?
