I would appreciate advice on a formula setup.
I would like to create a new calculated field in a BAQ which looks to see if both the OverridePriceList field and the LockPrice field each show True. If both are true, then I want to see True result, and if they both aren’t flagged as true then return a result of false.
Thank you
We don’t have any lines with any of these true for me to test, but it doesn’t bomb out, so it should work.
(case when QuoteDtl.OverridePriceList = 'true' and QuoteDtl.LockPrice = 'true' then 'true' else 'false' end)
Brandon,
thanks for the help, it worked.
My error was not using ’ ’ in each instance.
For a boolean (bit) field you should use 1 and 0 in SQL.
Don’t listen to him, he’s just mad that he didn’t get to the answer first…
But yes, true SQL is 1 and 0. Epicor will take either.
you messing with me stats man
