>if you can summarize a table in E9 the answerThe summarize problem in my case is probably version specific.
I was using 9.04.506 which has several known issues in the BAQ designer.
I installed a one off fix to take care of the worst - table joins, but I know it broke some other features.
--- In vantage@yahoogroups.com, "brad_boes" <bboes@...> wrote:
> I am a little confused on what the true question is, but if you are asking if you can summarize a table in E9 the answer is yes. We have many BAQ's like this.
> However, one of the limitations that is not supported is summarizing more than one table name. You can add the same table more than once as an alias and summarize the same table multiple times.
> We are on 9.05.603 and this all works.
> For example we summarize part material demand to the part by different warehouses using the alias method.
> Brad Boes
> Metalworks
> --- In vantage@yahoogroups.com, "b_ordway" <cooner_55421@> wrote:
> > I am curious about these in 9.05 too.
> > In V8 there is a "Summarize" checkbox for adding tables I want to display aggregate values for.
> > When I try to build a BAQ with aggregates E9, it often fails even though the syntax check is OK.
> > But I can import a V8 BAQ with a calculated count field into E9 and it works fine.
> > --- In vantage@yahoogroups.com, "supertico05" <mvissuet@> wrote:
> > > In Epicor 9.05 can you add a calculated field to a BAQ where the calculated field counts the number of times a field has a value in a table.
> > > A simple example of this would be on a Part BAQ, count the number of released jobs for that part number. So the fields displayed would be Part Number, Part Description, and Calculated Field- Job Count.
