I understand.
So you're aware this has apparently been fixed in 9.05.702, and Epicor ported the fix back to 9.05.700C for me which I tried earlier this week but it just brought back the XML error (although I'll test this again over the weekend).
--- In vantage@yahoogroups.com, "Hellings, Lauren" <lauren.hellings@...> wrote:
> No we haven't... the only "solution" that Epicor came back with was to spend a minimum of $6,000 to have our DB converted to SQL Unicode.. Not gonna happen at this point.. expensive fix for the Euro symbol to be correct in the software.
> Thank you,
> Lauren L. Hellings
> Business Analyst
> Cell: 832-472-1736
> email: Lauren.Hellings@...<mailto:Lauren.Hellings@...>
> www.c-p-i.com<http://www.c-p-i.com/>
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Clive
> Sent: Monday, July 8, 2013 6:05 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: BAQ Crystal Reports
> Hi Lauren,
> Did you ever manage to get the Euro currency symbol to work correctly for you ?.
> Code page options in the .pf file are screwing us up since going from Vantage 8 to Epicor 9 (MS SQL) a couple of weeks ago. The Euro symbol is now well and truly broken for us.
> Also this 'line' that is suggested in Epicor documentation is totally wrong (they have admitted this to me).
> Thanks.
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Hellings, Lauren" <lauren.hellings@<mailto:lauren.hellings@>> wrote:
> > Thank you for the help everyone. Turns out the issue was caused by a change to the pf file that was made the night before. We added a line to enable the Euro currency symbol to display within Epicor and apparently it doesn't play well with BAQs in general. Now that I have removed the change and restarted all appservers the BAQ reports are functioning correctly again.
> > Thank you,
> > Lauren L. Hellings
> > Business Analyst
> > Cell: 832-472-1736
> > email: Lauren.Hellings@<mailto:Lauren.Hellings@<mailto:Lauren.Hellings@%3cmailto:Lauren.Hellings@>...>
> ----------Legal Disclaimer----------
> The information contained in this message may be privileged and confidential, and is intended solely for the use of the named addressee. No other person is authorized to access, copy or re-use this message (or any information contained herein). If you are not the intended recipient, please notify us immediately by replying to this message and delete it from your computer.
