HI
We have two BAQ dataviews binded to a grid, however when clicking the retrieve button you have to click the grid to see the rows highlighted. I have tried clicking grid only and not having it ticked when going though the Rule Wizard. Is there a way upon retrieval to automatically see the row highlighted?
Please see my code below
// Custom code for CustomerTrackerForm
// Created: 11/10/2017 14:00:32
extern alias Erp_Contracts_BO_Company;
extern alias Erp_Contracts_BO_ARAgingTracker;
extern alias Erp_Contracts_BO_Customer;
extern alias Erp_Contracts_BO_CreditManager;
extern alias Erp_Contracts_BO_ARInvoice;
extern alias Erp_Contracts_BO_Quote;
extern alias Erp_Contracts_BO_CustCnt;
extern alias Erp_Contracts_BO_ARLOC;
extern alias Erp_Contracts_BO_CashDtlSearch;
extern alias Erp_Contracts_BO_ServiceContract;
extern alias Erp_Contracts_BO_CustShip;
extern alias Erp_Contracts_BO_CashRecSearch;
extern alias Erp_Contracts_BO_ARPromissoryNotes;
extern alias Erp_Contracts_BO_SalesOrdHedDtl;
extern alias Erp_Contracts_BO_OrderDtlSearch;
extern alias Erp_Contracts_BO_ShipDtlSearch;
extern alias Ice_Contracts_BO_DynamicQuery;
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using Ice.Lib.Broadcast;
using Infragistics.Win;
using Infragistics.Win.UltraWinGrid;
using System.Reflection;
using Ice.BO;
public class Script
Epacsys epac_sr 9 Sept 2021 Upgrade to Kinetic 2021.1.8. Tidied fields on Customer - Atributes tab
private BAQDataView bdvCustomer;
private BAQDataView bdvInvClosed;
private DataView Customer_DataView;
private EpiBaseAdapter oTrans_customerAdapter;
this.Customer_DataView = this.Customer_Row.dataView;
this.oTrans_customerAdapter = ((EpiBaseAdapter)(this.csm.TransAdaptersHT["oTrans_customerAdapter"]));
this.Customer_DataView.ListChanged += new ListChangedEventHandler(this.Customer_DataView_ListChanged);
bdvCustomer = new BAQDataView("InvoiceHedCustTracker");
oTrans.Add("InvoiceHedCustTrackerBAQ", bdvCustomer);
bdvInvClosed= new BAQDataView("InvoiceHedCustTracker(closed)");
oTrans.Add("InvoiceHedCustTrackerClosedBAQ", bdvInvClosed);
this.btnRun.Click += new System.EventHandler(this.btnRun_Click);
CreateRowRuleInvoiceHedCustTrackerBAQHDCase2_HDCaseStatusContains_CLOSED();;
CreateRowRuleInvoiceHedCustTrackerBAQHDCase2_HDCaseStatusContains_OPEN();;
this.btnRtv.Click += new System.EventHandler(this.btnRtv_Click);
CreateRowRuleInvoiceHedCustTrackerClosedBAQHDCase2_HDCaseStatusContains_OPEN();;
CreateRowRuleInvoiceHedCustTrackerClosedBAQHDCase2_HDCaseStatusContains_CLOSED();;
bdvCustomer = null;
bdvInvClosed = null;
this.btnRun.Click -= new System.EventHandler(this.btnRun_Click);
this.Customer_DataView = null;
this.oTrans_customerAdapter = null;
this.Customer_DataView.ListChanged -= new ListChangedEventHandler(this.Customer_DataView_ListChanged);
this.btnRtv.Click -= new System.EventHandler(this.btnRtv_Click);
// Begin Custom Code Disposal
// End Custom Code Disposal
private void CustomerTrackerForm_Load(object sender, EventArgs args)
// Add Event Handler Code
EpiBasePanel detailPanel1;
detailPanel1 = (EpiBasePanel)(csm.GetNativeControlReference("8fd5b1fa-db9e-423c-baca-4656696c859b"));
detailPanel1.Focus();
private void btnRun_Click(object sender, System.EventArgs args)
InvoiceHedCustTrackerBAQ();
private void InvoiceHedCustTrackerBAQ()
EpiUltraGrid grdOpenInv = (EpiUltraGrid)csm.GetNativeControlReference("35897ae0-bf81-4358-beaa-7b6b41599fa1");
int CustNum = 0;
if (Customer_Row.CurrentDataRow != null)
CustNum = (int)Customer_Row.CurrentDataRow["CustNum"];
string filter = "1 = 2";
bdvCustomer.dataView.RowFilter = filter;
using (DynamicQueryAdapter queryAdapter = new DynamicQueryAdapter(this.oTrans))
queryAdapter.BOConnect();
QueryExecutionDataSet dsExecute = new QueryExecutionDataSet();
dsExecute.ExecutionFilter.Clear();
dsExecute.ExecutionParameter.Clear();
dsExecute.ExecutionFilter.AddExecutionFilterRow("Customer", "CustNum", false, "=", CustNum.ToString(), Guid.Empty, null);
queryAdapter.QueryResults.Tables["Results"].Clear();
queryAdapter.ExecuteByID("InvoiceHedCustTracker", dsExecute);
bdvCustomer.dataView.Table = queryAdapter.QueryResults.Tables["Results"].Copy();
try //added
// table named results has results
grdOpenInv.DataSource = queryAdapter.QueryResults.Tables["Results"]; // vData is a pointer to my Grid
grdOpenInv.EpiAutoFit = true; // not sure this works!
// Cleanup Adapter Reference
queryAdapter.Dispose();
catch (System.Exception ex)
MessageBox.Show(ex.ToString());
} //ends
private void InvoiceHedCustTrackerClosedBAQ()
EpiUltraGrid grdClosedInv = (EpiUltraGrid)csm.GetNativeControlReference("95743524-42ab-4dbd-ad74-e6e2b347abc6");
int CustNum = 0;
bdvInvClosed.dataView.RowFilter = filter;
queryAdapter.ExecuteByID("InvoiceHedCustTracker(closed)", dsExecute);
bdvInvClosed.dataView.Table = queryAdapter.QueryResults.Tables["Results"].Copy();
try
grdClosedInv.DataSource = queryAdapter.QueryResults.Tables["Results"]; // vData is a pointer to my Grid
grdClosedInv.EpiAutoFit = true; // not sure this works!
private void CreateRowRuleInvoiceHedCustTrackerClosedBAQHDCase2_HDCaseStatusContains_CLOSED()
// Description: ClosedInvoicesClosedcase
// **** begin autogenerated code ****
ControlSettings myControlSettings = new ControlSettings();
myControlSettings.BackColor = System.Drawing.Color.LightGreen;
RuleAction errorInvoiceHedCustTrackerClosedBAQ_RowAction = RuleAction.AddRowSettings(this.oTrans, "InvoiceHedCustTrackerClosedBAQ", false, myControlSettings);
RuleAction[] ruleActions = new RuleAction[] {
errorInvoiceHedCustTrackerClosedBAQ_RowAction};
// Create RowRule and add to the EpiDataView.
RowRule rrCreateRowRuleInvoiceHedCustTrackerClosedBAQHDCase2_HDCaseStatusContains_CLOSED = new RowRule("InvoiceHedCustTrackerClosedBAQ.HDCase2_HDCaseStatus", RuleCondition.Contains, "CLOSED", ruleActions);
((EpiDataView)(this.oTrans.EpiDataViews["InvoiceHedCustTrackerClosedBAQ"])).AddRowRule(rrCreateRowRuleInvoiceHedCustTrackerClosedBAQHDCase2_HDCaseStatusContains_CLOSED);
// **** end autogenerated code ****
private void CreateRowRuleInvoiceHedCustTrackerClosedBAQHDCase2_HDCaseStatusContains_OPEN()
// Description: ClosedInvoiceOpencase
RuleAction errorInvoiceHedCustTrackerClosedBAQ_RowAction = RuleAction.AddRowSettings(this.oTrans, "InvoiceHedCustTrackerClosedBAQ", false, SettingStyle.Error);
RowRule rrCreateRowRuleInvoiceHedCustTrackerClosedBAQHDCase2_HDCaseStatusContains_OPEN = new RowRule("InvoiceHedCustTrackerClosedBAQ.HDCase2_HDCaseStatus", RuleCondition.Contains, "OPEN", ruleActions);
((EpiDataView)(this.oTrans.EpiDataViews["InvoiceHedCustTrackerClosedBAQ"])).AddRowRule(rrCreateRowRuleInvoiceHedCustTrackerClosedBAQHDCase2_HDCaseStatusContains_OPEN);
private void btnRtv_Click(object sender, System.EventArgs args)
InvoiceHedCustTrackerClosedBAQ();
private void Customer_DataView_ListChanged(object sender, ListChangedEventArgs args)
// Customer_DataView[0]["FieldName"]
// args.ListChangedType, args.NewIndex, args.OldIndex
// ListChangedType.ItemAdded, ListChangedType.ItemChanged, ListChangedType.ItemDeleted, ListChangedType.ItemMoved, ListChangedType.Reset
if (grdOpenInv.DataSource != null)
((DataTable)grdOpenInv.DataSource).Clear();
if (grdClosedInv.DataSource != null)
((DataTable)grdClosedInv.DataSource).Clear();
private void CreateRowRuleInvoiceHedCustTrackerBAQHDCase2_HDCaseStatusContains_CLOSED()
// Description: Open Invoices
RuleAction okInvoiceHedCustTrackerBAQ_RowAction = RuleAction.AddRowSettings(this.oTrans, "InvoiceHedCustTrackerBAQ", false, myControlSettings);
okInvoiceHedCustTrackerBAQ_RowAction};
RowRule rrCreateRowRuleInvoiceHedCustTrackerBAQHDCase2_HDCaseStatusContains_CLOSED = new RowRule("InvoiceHedCustTrackerBAQ.HDCase2_HDCaseStatus", RuleCondition.Contains, "CLOSED", ruleActions);
((EpiDataView)(this.oTrans.EpiDataViews["InvoiceHedCustTrackerBAQ"])).AddRowRule(rrCreateRowRuleInvoiceHedCustTrackerBAQHDCase2_HDCaseStatusContains_CLOSED);
private void CreateRowRuleInvoiceHedCustTrackerBAQHDCase2_HDCaseStatusContains_OPEN()
// Description: Open Invoices OpenCase
RuleAction errorInvoiceHedCustTrackerBAQ_RowAction = RuleAction.AddRowSettings(this.oTrans, "InvoiceHedCustTrackerBAQ", false, SettingStyle.Error);
errorInvoiceHedCustTrackerBAQ_RowAction};
RowRule rrCreateRowRuleInvoiceHedCustTrackerBAQHDCase2_HDCaseStatusContains_OPEN = new RowRule("InvoiceHedCustTrackerBAQ.HDCase2_HDCaseStatus", RuleCondition.Contains, "OPEN", ruleActions);
((EpiDataView)(this.oTrans.EpiDataViews["InvoiceHedCustTrackerBAQ"])).AddRowRule(rrCreateRowRuleInvoiceHedCustTrackerBAQHDCase2_HDCaseStatusContains_OPEN);
Regards
Kirsty
