Is there a way to find the earliest date across multiple tables in a BAQ?
I’m querying historical data which I pushed into a UD Table. So, forget native Epicor field names…
For a given job, I have:
Material Transactions (Table A)
Labor Transactions (Table B)
Subcontract Transaction (Table C)
Misc Transactions (Table D)
Each record in these tables has a transaction date.
I want to create a calculated field that populates with the earliest transaction date against a given Job.
I already have these tables in their own subqueries with calculated fields to determine the min(date) of each table. So, I have the first Labor Date, first Material Date, etc.
If I only had two tables, I can simply do a “case when dateA<dateB”.
But since I have more than two tables, do I need to create an insane “case when” statement to cover all scenarios… or… is there maybe a more simplified approach?
SQL has a “Least” function and a “Cross Apply”… but neither appear to be supported in Epicor’s BAQ’s.
You should be able to enter in something to the result that doesn’t mess with the results. Like today
isnull(field, GetDate())
Should handle what you need.
I don’t know what your data is, or what the end goal is, so you’ll have to adjust as necessary.
Also, I don’t know if you are grouping everything, or doing subqueries with a rejoin, but if it’s the latter, you can use a windowing function to get the earliest date without special subqueries.
Something like this.
min(isnull(field, GetDate())) over (partition by whateverFieldsYouNeedToPartitionBy)
…only if you want to return today’s date if all of the date values are in the future, or if all values are null. MIN() only returns the smallest non-null value.
I assumed he was getting errors, which is why I put that in there, and since it was historical data, it would all be in the past. But yeah, if the isnull isn’t needed, then even simpler.
