BAQ Filtering Question
My scenario is that I am creating a BAQ toshow the entire Order, when one of the lines meets a particular OrderDtl.ProdCode. How would I go about filtering a BAQ to show me orders that have a particular OrderDtl.ProdCode when the order will have multiple ProdCode?
For example, Order# XXX has 3 lines and 2 our of the 3 are for a prodcode of Chevy and one line that has a prodcode of Ford. I want to filter the BAQ to only show me orders that have a Ford Prodcode on the order and show me all 3 lines.
Hope that makes sense
I don’t know if you can do subqueries in E9. If you can, you can sum the
line numbers and act on a non-zero result.
I believe you would need to pull in the table a second time, as a summary table to show the order number and prodcode. Then inner join it by order number to the first instance of the table.
