BAQ/Progress: Comparing Boolean Values
Hi Andy.
This is fantastic! Thanks very much for your help. :)
Of Andy Watts
Sent: Monday, November 22, 2010 4:13 AM
Subject: [Vantage] Re: BAQ/Progress: Comparing Boolean Values
Hi Joe,
The only direct comparisons you can make between two boolean values are
Equals or Not Equals, for example:
If logX = logY Then...
If Not(logX = logY) Then...
You can't directly use greater than or less than comparisons, so you
might consider writing a little explicit logic thus:
If Not(logX) And Not(logY) Then... [logX is False, logY is False]
If Not(logX) And logY Then... [logX is False, logY is True]
If logX And Not(logY) Then... [logX is True, logY is False]
If logX And logY Then... [logX is True, logY is True]
This covers all bases. Note that If logX is the same as If logX = True
and If Not(logX) is the same as If logX = False - just less typing!
I hope this helps, if it isn't too late :-)
Regards,
Andy Watts, Ripley Engineering Ltd.
1. BAQ/Progress: Comparing Boolean Values
<http://groups.yahoo.com/group/vantage/message/95570;_ylc=X3oDMTJwbTIxdm
4yBF9TAzk3MzU5NzE1BGdycElkAzIwMzY5BGdycHNwSWQDMTcwNTAwNzE4MQRtc2dJZAM5NT
U3MARzZWMDZG1zZwRzbGsDdm1zZwRzdGltZQMxMjkwMDg0MDA5>
2. Posted by: "Joe Rojas" jrojas@...
<mailto:jrojas%40matsinc.com>
<mailto:jrojas@... <mailto:jrojas%40matsinc.com>
?Subject=%20Re%3A%20BAQ%2FProgress%3A%20Compar
ing%20Boolean%20Values> jagojoer <http://profiles.yahoo.com/jagojoer>
Wed Nov 17, 2010 2:13 pm (PST)
Hi All,
Is it possible to do comparisons between to Boolean field other than
equals?
I tested it out and couldn't get it work so I thought I ask the group.
For example, assuming that TRUE and FALSE are stored as something like
1/0 or -1/0 (and this could be the wrong assumption), we could end up
with the following possible combinations between two fields: 0 and 0, 1
and 1, 1 and 0, 0 and 1
I'd like to be able to compare Boolean 1 to Boolean 2 by using the
greater than or less than symbol.
Is this possible?
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
<mailto:jrojas%40matsinc.com> | www.matsinc.com Ask
us about our clean, green and beautiful matting and flooring
Tel: 01256-473940/464167
Mob:
www.ripley-eng.co.uk
Hi All,
equals?
Is this possible?
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Hi Joe,
Regards,
<mailto:jrojas@...?Subject=%20Re%3A%20BAQ%2FProgress%3A%20Compar
Hi All,
equals?
Is this possible?
jrojas@... <mailto:jrojas%40matsinc.com> | www.matsinc.com Ask
Mob:
