BAQ Report Scheduling Issue
Good morning all! I’m having an issue with scheduling a report I just finished creating. Simple BAQ that reports on employee’s remote schedules, muster group location and supervisor name. When designing the report I had saved the output as Excel. Now when I went to schedule the report I chose Excel as my output and setup my email, to reoccur Daily at 1AM.
I know it’s probably something simple I’m missing. But I’m stumped as of right now :pensive:
This is the error I’m receiving from the task history:
Program Ice.Services.Lib.RunTask when executing task 310304 raised an unexpected exception with the following message: RunTask:
System.InvalidOperationException: No printer found in the printer settings. Printer is optional only if Email settings are present.
   at Ice.Core.SsrsReporting.ReportProcessorBase.RenderReportForPrintOrEmailReport(RenderedSsrsReport renderedReport, Boolean serverSidePrint, Boolean ignorePageSettings) in C:\_releases\ICE\ICE4.2.300.8\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 449
   at Ice.Core.SsrsReporting.ReportProcessorBase.ProcessReportPart(String reportLocation) in C:\_releases\ICE\ICE4.2.300.8\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 166
   at Ice.Core.SsrsReporting.StandardReportProcessor.ProcessReportParts() in C:\_releases\ICE\ICE4.2.300.8\Source\Server\Internal\Lib\TaskLib\SsrsReporting\StandardReportProcessor.cs:line 34
   at Ice.Core.RoutingAndBreaking.ReportPersister.Persist(ReportInstanceInformation reportInstance, Func`2 reportsRenderer, Action`1 fillSysRptLstRow, Action`2 processReport, Func`3 filterTableAttachmentsFunc) in C:\_releases\ICE\ICE4.2.300.8\Source\Server\Internal\Lib\TaskLib\RoutingAndBreaking\ReportPersister.cs:line 58
   at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.RenderUnroutedSsrsReport() in C:\_releases\ICE\ICE4.2.300.8\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 359
   at Ice.Core.RptBase.ReportDatabaseBuilder.XMLClose() in C:\_releases\ICE\ICE4.2.300.8\Source\Server\Internal\Lib\TaskLib\RptBase\ReportDatabaseBuilder.cs:line 93
   at Ice.Core.RptTaskBase`1.XMLClose() in C:\_releases\ICE\ICE4.2.300.8\Source\Server\Internal\Lib\TaskLib\RptBase\RptTaskBase.cs:line 260
   at Ice.Core.RptTaskBase`1.RunDynamicCriteriaReport(IEnumerable`1 criteriaParameters, IEnumerable`1 criteriaMappings) in C:\_releases\ICE\ICE4.2.300.8\Source\Server\Internal\Lib\TaskLib\RptBase\RptTaskBase.cs:line 163
   at Ice.Lib.DynamicCriteria.DynamicCriteriaReport.RunProcess(Int64 instanceTaskNum, String outputFileName) in C:\_releases\ICE\ICE4.2.300.0\Source\Server\Internal\Lib\DynamicCriteria\DynamicCriteriaReport.cs:line 44
   at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in C:\_releases\ICE\ICE4.2.300.8\Source\Server\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 68
   at Ice.Hosting.TaskCaller.ExecuteTask() in C:\_releases\ICE\ICE4.2.300.8\Source\Server\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 64
   at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in C:\_releases\ICE\ICE4.2.300.0\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 63
   at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in C:\_releases\ICE\ICE4.2.300.0\Source\Server\Services\Lib\RunTask\RunTask.cs:line 450
When you schedule it, chose generate with the email options set instead of print.
Hey Kevin, to clarify I’m setting it up like this, then click the Email option
These are the report style options:
I forgot to add, that I can email the report on-demand. It just errors on when it tries to run on schedule.
