BAQ Reports in Multiple Companies
Yeah at least with dashboards I find you have to do this:
1. Get the dashboard working exactly as you want it in Company A.
2. Remember the exact name you gave it in Company A.
3. Export the Dashboard with BAQs.
4. Go to Company B. Import Dashboard and BAQs. If you have
system BAQs, skip them since you can't overwrite them. The dashboard in
Company B will have BAQs with the Company B prefix.
5. Make sure you give the Dashboard the *exact same* name as you
did in Company A. Also make sure the description matches so you're not
confused.
6. Go to menu maintenance and link the dashboard where you want
it.
7. Now refresh your session. The dashboard should run as expected
in both companies.
If you find yourself reimporting because something got screwed up, be
sure to delete your custom BAQs before reimporting, as at least in .405
it won't let you overwrite the BAQ on import.
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
Picometrix
bspolarich@... ~ 734-864-5618 ~
www.advancedphotonix.com
Of Lynn
Sent: Tuesday, January 13, 2009 12:00 PM
Subject: [Vantage] Re: BAQ Reports in Multiple Companies
Brian:
By the way, thanks for that extra information about the Dashboards.
I was wondering why a dashboard I created last week didn't show up
when I changed companies.
lynn
"Lynn" <lynn.khalife@...> wrote:
> We have had the same exact problem a couple of times: Shared,
global
> BAQs were not being passed from one company to the others. Each
time
> our problem was a result of Sonic not working.
> It took a couple of weeks to troubleshoot with the help of Epicor
> Support and each time the problem was corrected by a change in
> settings with the Sonic setup. (We have yet to identify why Sonic
> quits working sometimes.)
> I recommend you log a support call with Epicor. It may take a
couple
> of days just to get the call assigned to a person with actual
working
> knowledge of Sonic and Multi-company setup. I'm not sure that
there
> are many people at Epicor who understand how information is passed
in
> the Multi-Company features.
> It's too bad they haven't yet published an AnswerBook with a Step-
by-
> step instructions for troubleshooting and diagnosing Multi-company
> problems.
> Anyway, after Sonic was working properly again, then I had to go
and
> touch each BAQ by making some minor change and re-saving each one
in
> order to force the system to pass the BAQs to the other companies.
> We're on Vantage 8.03.404 Progress.
> Lynn
"Brian W. Spolarich "
> <bspolarich@> wrote:
> > We're on Vantage 8.03.405 SQL with MulitCompany.
> > I have a BAQ Report that I have published to the menu, and I
want
> it
> > to be available in two companies. The report uses a BAQ that
> exists in
> > Company A, but doesn't exist in Company B. The report is
visible,
> but
> > when I run it no output is produced and I get an error in the
system
> > monitor saying the query doesn't exist. I look in the BAQ tool
and
> > indeed the query isn't present.
> > I've always been a bit fuzzy on how various pieces of the
system
> tools
> > interact across companies. I just spent an hour untangling a
> dashboard
> > issue, as dashboards and their queries seem to be completely
> partitioned
> > across companies, so a dashboard on the menu must have the same
> name in
> > every company, and when you import it, the BAQ gets its name
> changed to
> > be prefixed with the current company. So as long a you're
careful
> with
> > naming things the same every time it doesn't hurt too bad to set
> this
> > up.
> > I have marked the BAQ as global in the source company, and I
think
> > that's what I need to have working in order for this to work
> properly.
> > I do see this in MultiCompany.log immediately after I marked the
> BAQ as
> > global:
> > 01/13/09 10:37:45 (VULCAN:8301) Multi-Company Process - Processing
> > 01/13/09 10:37:45 (VULCAN:8301) Multi-Company Process - Starting
> Sonic
> > Session (TCP://localhost:2506)
> > 01/13/09 10:37:46 (VULCAN:8301) Multi-Company Process - 1 Outbound
> > Records Processed (PICO/CORP)
> > Records Processed (PICO/CONS)
> > 01/13/09 10:38:07 (VULCAN:8301) Translation Error - Exports
record
> is
> > not available.
record
> is
> > not available.
> > 01/13/09 10:38:07 (VULCAN:8301) Multi-Company Process - 2 Inbound
> > Records Processed
> > 01/13/09 10:38:07 (VULCAN:8301) Multi-Company Process - Completed
> > What I don't see is a indication of a record sent *to* the
target
> > company I'm interested in, OPTO.
> > So I'm guessing that the problem is that I need to have
> MultiCompany
> > setup to send records from PICO to OPTO. However I don't want to
> send
> > Parts, Customers, Suppliers, or anything like that directly
between
> the
> > two companies. Can I just setup the PICO-OPTO links in External
> Company
> > Maintenance, but not configure any of the detail and get what I
> want?
> > Does anyone know what the "exports record is not available" error
> means?
> > -bws
> Photonix /
> > Picometrix
> > bspolarich@
> > <mailto:bspolarich@> ~ 734-864-5618 ~
> > www.advancedphotonix.com <http://www.advancedphotonix.com>
I have a BAQ Report that I have published to the menu, and I want it
to be available in two companies. The report uses a BAQ that exists in
Company A, but doesn't exist in Company B. The report is visible, but
when I run it no output is produced and I get an error in the system
monitor saying the query doesn't exist. I look in the BAQ tool and
I've always been a bit fuzzy on how various pieces of the system tools
interact across companies. I just spent an hour untangling a dashboard
issue, as dashboards and their queries seem to be completely partitioned
across companies, so a dashboard on the menu must have the same name in
every company, and when you import it, the BAQ gets its name changed to
be prefixed with the current company. So as long a you're careful with
naming things the same every time it doesn't hurt too bad to set this
up.
I have marked the BAQ as global in the source company, and I think
that's what I need to have working in order for this to work properly.
I do see this in MultiCompany.log immediately after I marked the BAQ as
global:
01/13/09 10:37:45 (VULCAN:8301) Multi-Company Process - Starting Sonic
01/13/09 10:38:07 (VULCAN:8301) Translation Error - Exports record is
not available.
not available.
Records Processed
What I don't see is a indication of a record sent *to* the target
So I'm guessing that the problem is that I need to have MultiCompany
setup to send records from PICO to OPTO. However I don't want to send
Parts, Customers, Suppliers, or anything like that directly between the
two companies. Can I just setup the PICO-OPTO links in External Company
Maintenance, but not configure any of the detail and get what I want?
Does anyone know what the "exports record is not available" error means?
-bws
Picometrix
up.
global:
not available.
not available.
Records Processed
-bws
Picometrix
bspolarich@...
<mailto:bspolarich@...> ~ 734-864-5618 ~
We have had the same exact problem a couple of times: Shared, global
BAQs were not being passed from one company to the others. Each time
I recommend you log a support call with Epicor. It may take a couple
of days just to get the call assigned to a person with actual working
knowledge of Sonic and Multi-company setup. I'm not sure that there
are many people at Epicor who understand how information is passed in
It's too bad they haven't yet published an AnswerBook with a Step-by-
problems.
Anyway, after Sonic was working properly again, then I had to go and
touch each BAQ by making some minor change and re-saving each one in
Lynn
--- In vantage@yahoogroups.com, "Brian W. Spolarich "
it
exists in
but
tools
dashboard
partitioned
name in
changed to
with
this
> up.
properly.
BAQ as
> global:
Sonic
is
> not available.
is
> not available.
> Records Processed
MultiCompany
send
the
Company
want?
means?
> -bws
Photonix /
> Picometrix
> bspolarich@...
Brian:
lynn
global
time
couple
working
there
in
by-
> problems.
and
in
> Lynn
want
> it
> exists in
visible,
> but
system
and
system
> tools
> dashboard
> partitioned
> name in
> changed to
careful
> with
> this
> > up.
think
> properly.
> BAQ as
> > global:
> Sonic
record
> is
> > not available.
record
> is
> > not available.
> > Records Processed
target
> MultiCompany
> send
between
> the
> Company
> want?
> means?
> > -bws
> Photonix /
> > Picometrix
> > bspolarich@
