Yes, for dashboards that use publish and subscribe what I usually do is have the published on top, the subscribe below and another tab next to the subscribed tab that does NOT subscribe, but instead shows all data (as long as that dataset is not too large) – and the crystal report is based off of the published area and the non subscribed tab.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of SimsTrak Consulting
Sent: Wednesday, January 15, 2014 4:48 PM
Subject: RE: [Vantage] BAQ Reports - Multiple Sources
Vic,
Thanks! That's exactly what I need. This particular application is looking
at a 12-month window of data, so a nightly dump of the data is likely
sufficient.
I've tried dashboard reports in the past, but when I had them in a publish
and subscribe mode, it didn't seem to give me all the data from both
datasets, only the ones that it was subscribed to. So, for example, if I
had a panel on my DB with customers, and published the customer to another
panel with shipments by customer, the dashboard report didn't pull in all
customers, only the ones I had selected. This was versions ago when I did
this (probably v8), and maybe it was just user-error on my part.
Kevin
Vic Drecchio
Sent: Wednesday, January 15, 2014 2:43 PM
I do multiple BAQ's, use the BAQ Export process to dump them all
periodically to a shared folder (every hour?) and then I can hit as many
BAQ's as I want. Worst case, the data is one-hour old or however often I
refresh them in the System Agent.
SimsTrak Consulting
Sent: Wednesday, January 15, 2014 11:40 AM
Subject: [Vantage] BAQ Reports - Multiple Sources
Has anyone figured out a good way to get a BAQ report that requires more
than one BAQ? For example, if I wanted a report that showed me invoiced
dollars (from InvcHead/InvcDtl) as well as sales orders (from
OrderHed/OrderDtl) for a period of time, I can't write one BAQ that gives me
all that information.
The way I've typically handled this is by writing one of these reports as a
BAQ report, and then the other report becomes a subreport using an ODBC
connection to the database. If I'm trying to eliminate ODBC connections, I
don't really see another way around this.
Any ideas?
Kevin Simon
