Hello experts!
I’ve been asked to deliver a list of all method and data directives that trigger emails as part of the bpm. Has anyone built a baq/dashboard to display the directive and even the email addresses tied to the directive?
Steve
Hello experts!
Steve
That’s tough cause you’re using variables in the widget at times if the email address is based on a field (dynamic), though if you are typing it out that should be in there as plain text.
Either way, I think @hkeric.wci linked me the table the other day because I needed to do something similar. Bartender Printer not printing in BT file - #6 by hkeric.wci
The table BpDirective has a field called Body. This is where those emails or variables would show up. I hope this helps. Good luck!
@Cyclonaut, if you query that table and the field @NateS just talked about, you’ll see what @chaddb is showing you here… so if you can make something out of that, that’s how it works.
Wow… Wonsil to the rescue. Fire post… will not forget that.
