BAQ with Parameters v9.05.6
To clarify, I am trying to run the Utilities > Business Activity Query Export Process to export the Part records to a csv file. The concept was to create one BAQ with a parameter that would allow the end user to choose to the Type of parts to export.
Rob.
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> BAQ Export as in BAQ Designer -> Actions -> Export BAQ?
> If that's the case you are exporting the physical file which allows you to
> move the BAQ from DB to DB. Maybe I am misunderstanding
> Thanks!
> *Jose C Gomez*
> *Software Engineer*
> *checkout my new blog <http://www.usdoingstuff.com> *
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> *Quis custodiet ipsos custodes?*
> On Fri, May 18, 2012 at 7:35 AM, robmcfarlin@... <
> RobM@...> wrote:
> > We are attempting to create a BAQ with parameters to filter the records to
> > be exported. In this case, Part table with TypeCode as parameter.
> > In the BAQ Designer, when tested, it will pop up a Parameters window,
> > allows you to select the TypeCode you want, and it displays the correct set
> > of records.
> > However, when we run it through the BAQ Export Process, it just runs
> > without giving you the option to select the parameter.
> > Has any body else tried tried this?
> > Rob McFarlin, CPA
> > Controller
> > Accel Group Inc
We are attempting to create a BAQ with parameters to filter the records to be exported. In this case, Part table with TypeCode as parameter.
In the BAQ Designer, when tested, it will pop up a Parameters window, allows you to select the TypeCode you want, and it displays the correct set of records.
However, when we run it through the BAQ Export Process, it just runs without giving you the option to select the parameter.
Rob McFarlin, CPA
Controller
Accel Group Inc
Thanks!
*Jose C Gomez*
*Software Engineer*
E: jose@...
> of records.
> Rob McFarlin, CPA
> Controller
> Accel Group Inc
Ive noticed this too and thought it was a design 'feature'. If there's a work-around, I'd be interested in it too.
> Rob McFarlin, CPA
> Controller
> Accel Group Inc
Good Day Rob:
I never had a problem with exporting except that it marks it NOT
shared.
What is the problem? You moved it to a new db and now does not work?
You may have to redefine the Parameters for the prompts.
You are running it as a BAQ search from a field -- that does not work. A
BAQ search will not ask for parameters, and will do odd things with
'fixed' criteria.
Must create a Quick-Search based on the BAQ and run it from a
field search.
Len
Leonard C. Hartka, IT Director\ERP Manager
Sun Automation Group
66 Loveton Circle
Sparks, Md. 21152
410-329-3560 ext. 120
410-329-3564 FAX
443-255-7192 Work Cell
len.hartka@...
Of Jose Gomez
Sent: Friday, May 18, 2012 8:25 AM
Subject: Re: [Vantage] BAQ with Parameters v9.05.6
to move the BAQ from DB to DB. Maybe I am misunderstanding
Thanks!
*Jose C Gomez*
*Software Engineer*
E: jose@...
parameter.
> Rob McFarlin, CPA
> Controller
> Accel Group Inc
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
