Hello,
I got a problem with my BAQReport, my Task Manager say it’s complete but my file don’t save. I try to generate it by a button click.
he generate if i use the BAQ Report Designer, so I thinks it’s not my SSRS. I try to generate another one(BAQ Report) and It’s work fine. After that I took this code to complete mine, but it doesn’t work at all.
After this I try to do a Tracing with the BAQ Report Designer for seeing the filter and the parameter, but everything seem’s fine !
This is my code
System.IO.Directory.CreateDirectory(path);
//_BAQReport.clearData();
_BAQReport.GetNewParameters();
var paramRow = _BAQReport.ReportDataSet.BAQReportParam[0];
paramRow.BAQID = "EtiquetteST";
paramRow.ReportTitle = "Matiere Structurel";
paramRow.BAQRptID = ("LabelST");
paramRow.ReportID = ("LabelST");
paramRow.TaskNote = "Etiquette Structurel";
paramRow.Character01 =path+fileName;
paramRow.AgentID = "System Agent";
paramRow.UserID = session.UserID;
paramRow.Filter1 ="<DynamicReportDataSet xmlns=\"http://www.epicor.com/Ice/300/BO/DynamicReport/DynamicReport\"><BAQReport><Company></Company><BAQRptID>LabelST</BAQRptID><Description>Etiquette pour la matiere Structurel</Description><ReportTitle /><FormTitle>Etiquette pour la matiere Structurel</FormTitle><ExportID>EtiquetteST</ExportID><SystemFlag>false</SystemFlag><Completed>false</Completed><GlobalReport>false</GlobalReport><IsCrystalReport>false</IsCrystalReport><ReportID>LabelST</ReportID><CrystalReportName /><CGCCode /><SSRSReportName>LabelST.rdl</SSRSReportName>"+/*<SysRevID>117324380</SysRevID><SysRowID>8ca844c9-e50c-48f8-b0bd-daeaa3ce67d5</SysRowID>*/"<TempRowID /><BitFlag>0</BitFlag><RowMod /></BAQReport><BAQRptOptionFld><BAQRptID>LabelST</BAQRptID><DataTableID>PartBin</DataTableID><FieldName>LotNum</FieldName><CompOp>=</CompOp> <Seq>1</Seq> <DefaultValue /> <FieldLabel>Lot Number</FieldLabel> <DisplayName>PartBin_LotNum</DisplayName><FieldFormat>x(30)</FieldFormat> <EpiGuid>f5ad598d-6aea-40e7-9f61-7b894a1b89f0</EpiGuid> <IsVisible>false</IsVisible> <DataType>nvarchar</DataType> <SystemFlag>false</SystemFlag> <DispOrder>0</DispOrder>" /*<SysRevID>117324687</SysRevID><SysRowID>cbc4b2e2-f871-429e-907c-016e952aaa9f</SysRowID>*/+"<FieldValue>" + lot + "</FieldValue><TempRowID>Field1</TempRowID><BitFlag>0</BitFlag><RowMod /></BAQRptOptionFld></DynamicReportDataSet>";
paramRow.Option01 = lot;
//paramRow.Option01 = "0";
paramRow.AutoAction = "SSRSPREVIEW"; //Imprimer le rapport.
paramRow.SSRSRenderFormat = "PDF";
paramRow.ReportStyleNum = 1; //
_BAQReport.SubmitToAgent("System Agent", 0, 0, "LabelST");
PS : The folder is create so it can’t be my path !
