BAQReportParameters - Filter1
Roel,
It gets complicated when not all receipts are inspected within the
filter dates, thus they don't have INSPECTED date, in that case we must
use the cutoff date as the second date.
Mike Tonoyan / Natel Engr.
mtonoyan@...
Of Roel Martinez
Sent: Wednesday, July 20, 2011 8:24 AM
Subject: [Vantage] RE: BAQReportParameters - Filter1
Mike, is my approach too simplistic or should you just bring the
RcvDtl.ReceiptDate and RcvDtl.InspectedDate and subtract the 1st from
the 2nd for your "INSPECTION DAYS"? Sorry, I have not used Inspection in
a very long time and might be completely off your purpose....
Regards.
Roel Martinez
ERP Analyst
SABRE TUBULAR STRUCTURES (tm)
www.sabretubularstructures.com<http://www.sabretubularstructures.com/>
8653 E. Hwy 67 | Alvarado, TX 76009
Phone: 817-852-1700 ext. 11858 | Direct Line: 817-852-1858 |Fax:
817-852-1705
Behalf Of Mike Tonoyan
Sent: Tuesday, July 19, 2011 4:47 PM
Subject: [Vantage] BAQReportParameters - Filter1
Finally I was able to manually create the RI_Aging.rpt file, which I was
struggling with earlier.
Now I have another question, I need to create a calculated field to find
number of days the PO Receipt was in the Receiving Inspection area. One
of the BAQ report options is the cutoff date. Is there any way to
capture the cutoff date in Crystal Reports? I can see the date when I
browse the Filter1 in BAQReportParameters. Do I need to create a formula
to fetch the data I need or there is an easy way?
mtonoyan@... <mailto:mtonoyan%40natelengr.com>
__________________________________________________________
Notice: This email transmission may contain confidential information and
is intended only for the person(s) named. Any use, copying or disclosure
to/by any other person(s) is strictly prohibited. By accepting this
information, recipients confirm that they understand and will comply
with all applicable ITAR and EAR requirements.
______________________________________________________________________
Notice: This email transmission may contain confidential information and is intended only for the person(s) named. Any use, copying or disclosure to/by any other person(s) is strictly prohibited. By accepting this information, recipients confirm that they understand and will comply with all applicable ITAR and EAR requirements.
We're trying to add 2 method directives to the JobEntry screen. We'd simply like to record the time and date of when the JobEngineered and JobReleased fields are checked, the first time. I added them as pre-processing directives. They worked fine in the test company so I exported them and imported into our live database. After I enabled them, users started calling reporting an error, "Record has been modified by another user and couldn't be updated. Please press the Refresh button and re-enter your changes," when they try to save the job after clicking either JobEngineered or JobReleased. The workaround was to un-click Engineered and then save. Seems like it's a timing issue between the two directives.
They are both added as Pre-Processing directives. Here they are...
JobEngineered Conditions
the JobHead.JobEngineered field of the changed row is equal to the True value and the JobHead.Date04 field of the changed row is equal to the ? value
JobEngineered Actions
for each ttJobHead where ttJobHead.JobEngineered = True no-lock. Assign ttJobHead.Date04 = Today. End.
JobReleased Conditions
the JobHead.JobReleased field of the changed row is equal to the True value and the JobHead.Date05 field of the changed row is equal to the ? value
JobReleased Actions
for each ttJobHead where ttJobHead.JobReleased = True no-lock. Assign ttJobHead.Date05 = Today. End.
Any thoughts?
Bruce
I haven't seen pre-processing directives generate that error before.
The only thing I can think of would be to add checks to make sure rowmod =
'A' or 'U'. Perhaps it's getting upset because you're changing rows that
aren't flagged as updates.
Conversely, you might be able to just set the rowmod to 'U' manually.
However I think there are issues with doing that in some cases. It's not a
method I use so I'm not too familiar with it.
> value
> JobReleased Actions
> Any thoughts?
> Thanks,
> Bruce
*Waffqle Driggers*
*High End Dev, System Design, Profit Drinking
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
I did a little testing. If you just check the boxes it does save the record and the dates but if you make a change to another field on the screen (like another custom date field we've added) then the error pops up when you click the save button.
I'll try the rowmod A/U, I think I accidentally left that out.
> > value
> > JobReleased Actions
> > Any thoughts?
> > Thanks,
> > Bruce
> *Waffqle Driggers*
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
That was it, the Add/Update test. Here's the code that fixed it. I'm not sure of the difference between no-lock and exclusive-lock and the BPM manual is not clear but I went ahead and changed it to exclusive.
for each ttJobHead where (ttJobHead.RowMod= 'A' or ttJobHead.RowMod= 'U') and ttJobHead.JobEngineered = True Exclusive-lock. Assign ttJobHead.Date04 = Today. End.
Thank you for the help!
> > > value
> > > JobReleased Actions
> > > Any thoughts?
> > > Thanks,
> > > Bruce
> > *Waffqle Driggers*
> > *:: 904.962.2887*
> > *:: waffqle@*
> > *:: NO FAXES*
Per this code, it does successfully record the date but we'd like to record in date and time format. How would I change the "= Today" to have it store the date and time?
> > > > value
> > > > JobReleased Actions
> > > > Any thoughts?
> > > > Thanks,
> > > > Bruce
> > > *Waffqle Driggers*
> > > *:: 904.962.2887*
> > > *:: waffqle@*
> > > *:: NO FAXES*
I have created a BAQ Report in the BAQ Report Designer, everything works
fine until I want to create the Crystal Reports. When I click on "Design
Crystal Reports" Crystal Reports program starts then immediately
prompts that cannot find the .rpt file. Has anyone had this problem? Is
it possible to bypass this step and create the report manually?
mtonoyan@...
Crystal Report Executable: C:\Program Files (x86)\Business
Objects\Crystal Reports 11.5\crw32.exe
Sample Data Directory: C:\_BAQReports\SampleData
Local Reports Directory: C:\_BAQReports\Reports
Server Reports Directory:
\\ntlcht-epiapp01\Epicor904\server\reports\CustomReports
<file:///\\ntlcht-epiapp01\Epicor904\server\reports\CustomReports>
BAQ Report Template: BAQReport.rpt
Copy Report Locally: Checked
mtonoyan@...
Of cooner_55421
Sent: Monday, July 18, 2011 3:52 PM
Subject: [Vantage] Re: BAQ Report Designer issues
Hi Mike,
Is the report name visible in the BAQ report designer?
If so, then I would look in the servers custom report directory & see if
the file is there.
Path is usually something like \\server\epicor\mfgsys\reports\custom
reports\
BTW... what do your options look like in the BAQ report designer?
Menu item - Actions, BAQ report options
The local and server reports directories.
works
"Design
Is
> mtonoyan@...
Hi Bruce,
I searched both C:\ and D:\ drives on the appserver, nowhere to be
found.
mtonoyan@...
Of cooner_55421
Hi Mike,
the file is there.
reports\
works
"Design
Is
> mtonoyan@...
When you start a new BAQ-based Crystal Report, Vantage 8 / Epicor 9 copies a file ( .....\Reports\CustomReports\BAQReport.rpt) to the path specified in Options (defaults to C:\_BAQReports\Reports). Possible problems are the original file was deleted or there is a permissions problem at the destination. The short term fix would be to copy BAQReport.rpt to the new file name and go to work. You would have to set a database location anyway so the additional work is minimal.
--- In vantage@yahoogroups.com, "Mike Tonoyan" <mtonoyan@...> wrote:
> Hi Bruce,
> found.
> mtonoyan@...
> Of cooner_55421
> Hi Mike,
> the file is there.
> reports\
> works
> "Design
> Is
> > mtonoyan@
You can use 'Now' instead of 'Today' to get the current datetime. However,
if I recall correctly the type on Epicor's date fields is Date, not
DateTime. You'd need to stick the DateTime is one of the character fields.
Not too hard, but it makes it a bit less convenient to handle later.
> the date and time?
> Today. End.
> rowmod =
> that
> not a
> We'd simply
> JobReleased
> and
> started calling
> couldn't
> changes," when
> JobReleased.
> it's a
> True
> the ?
> > > > > value
> Assign
> True value
> value
> > > > > JobReleased Actions
> Assign
> > > > > Any thoughts?
> > > > > Thanks,
> > > > > Bruce
> > > > *Waffqle Driggers*
> > > > *:: 904.962.2887*
> > > > *:: waffqle@*
> > > > *:: NO FAXES*
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
You can just as well create a blank report in Crystal and give it your
dataset. We've done it lots of times.
> > Hi Bruce,
> > found.
> > mtonoyan@...
> > Of cooner_55421
> > Hi Mike,
> > the file is there.
> > reports\
> > works
> > "Design
> > Is
> > > mtonoyan@
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
I'll have to test this out. On the Job Entry screen we have the Date01 field for manual entry. When you enter a date, it does also enter the time (12:00:00 AM unless you manually override). When I run a BAQ test on it, it only shows the date but I bet Crystal will show the time. I changed the actions in our test company to reflect =Now instead of =Today. I'll post an update after I verify with a Crystal Report.
> > the date and time?
> > Today. End.
> > rowmod =
> > that
> > not a
> > We'd simply
> > JobReleased
> > and
> > started calling
> > couldn't
> > changes," when
> > JobReleased.
> > it's a
> > True
> > the ?
> > > > > > value
> > Assign
> > True value
> > value
> > > > > > JobReleased Actions
> > Assign
> > > > > > Any thoughts?
> > > > > > Thanks,
> > > > > > Bruce
> > > > > *Waffqle Driggers*
> > > > > *:: 904.962.2887*
> > > > > *:: waffqle@*
> > > > > *:: NO FAXES*
> *Waffqle Driggers*
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
Good morning.
The Crystal document (.rpt) should be automatically created in the folder mentioned below ( <epicorserver>:\\epicor\mfgsys803\server\reports\customreports). I usually don't go through the "Design Crystal Report" path, this is what I do with very little problems:
1- I create my BAQ Report
2- From the Actions menu I do a "Test Report Form" (which creates the first xml file and the actual Crystal form).
3- I open Crystal and look for the "new" report in the mentioned directory.
4- I PrintPreview it and browse for my "fresh" xml file (in the ADO.NET(XML) dialog). This xml file will reside temporarily in the user's data file (<epicorserver>:\epicor\mfgsysdata\ reports\"username"\). Click Finish.
5- The preview will be empty. I go to the Database menu > Database Expert and move the Report Dataset below "Current Connections" to the right (Selecting "Report Dataset" and clicking on the ">>" button). This will actually put data into your Crystal form to start designing the report.
Let me know if you have any questions and call me if I can further assist you.
Regards.
Roel Martinez
ERP Analyst
SABRE TUBULAR STRUCTURES ™
Phone: 817-852-1700 ext. 11858 | Direct Line: 817-852-1858 |Fax: 817-852-1705
> --- In vantage@yahoogroups.com, "Mike Tonoyan" <mtonoyan@> wrote:
> > Hi Bruce,
> > found.
> > mtonoyan@
> > Of cooner_55421
> > Hi Mike,
> > the file is there.
> > reports\
> > works
> > "Design
> > Is
> > > mtonoyan@
Thank you all for replying. I added the dataset manually, it worked.
mtonoyan@...
Of al2trace
Sent: Tuesday, July 19, 2011 4:41 AM
> Hi Bruce,
> found.
> mtonoyan@...
Behalf
> Of cooner_55421
> Hi Mike,
if
> the file is there.
> reports\
> works
> "Design
> Is
> > mtonoyan@
and
mtonoyan@...
Mike, is my approach too simplistic or should you just bring the RcvDtl.ReceiptDate and RcvDtl.InspectedDate and subtract the 1st from the 2nd for your "INSPECTION DAYS"? Sorry, I have not used Inspection in a very long time and might be completely off your purpose....
Regards.
Roel Martinez
ERP Analyst
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mike Tonoyan
mtonoyan@...<mailto:mtonoyan%40natelengr.com>
