Barcode Scan vs Keyboard Entry
In this case it is an MC9090 mobile. I am acutally going to hardcode it to send a prefix & suffix & use that to flag if it was manual or scanned. Since they should only be scanning numbers I will just use a character sequence. Then I will just strip them out & populate the needed field. Hoping this will work since I assumed I would get the answer you just gave.
--- In vantage@yahoogroups.com, "k99ja04" <jallmond@...> wrote:
> Depends which model barcode scanner. Most impersonate keyboards. Some even connect inline with a Y cable straight to PS/2 port. How does yours connect? You're probably hosed here as the scanner looks like a really fast keyboard to the system.
> Jared
> --- In vantage@yahoogroups.com, "mmcwilliams22" <mmcwilliams22@> wrote:
> > We are trying to find a way to determine if a user keyed in a number or if they used the barcodes. We are having an accuracy problem in a department that we should not be seeing if they are using the barcodes. I tried using the keydown event but the keyboard & scanner both seem to act the same.
Jared
