what if you use the windows explorer to go to that location.
Location not found error
Yash do you have teams?
Yes I do
Hi All,
was there any solution for this ? the data generated in the MAP file is having only one row but printing directly to the printer it is having multiple prints on the label.
hi
were you able to figure out the issue, we are having the same i checked all the setting and in bartender and XML shows 1 record but it prints 4 records in the label printer
Can you show the XML? There are print settings in the XML I thought, but maybe I am wrong?
Below is the file generated in Bartender, it has 2 records but on the printer it printed 4
%BTW% /AF=“c:\Bartender\Labels\RollerShade_BarCode.btw” /D=“” /PRN=“” /DBTEXTHEADER=3 /R=3 /P
%END%
“_JobHead_RptLanguageID”,“_JobHead_Company”,“_JobHead_JobNum”,“_JobHead_PartNum”,“_JobHead_Calc_BOMSequence”,“_JobHead_Calc_custADDR1”,“_JobHead_Calc_custADDR2”,“_JobHead_Calc_custADDR3”,“_JobHead_Calc_custCITY”,“_JobHead_Calc_custCountry”,“_JobHead_Calc_custID”,“_JobHead_Calc_custName”,“_JobHead_Calc_custStat”,“_JobHead_Calc_custZIP”,“_JobHead_Calc_LangID”,“_JobHead_Calc_MultiJobParts”,“_JobHead_Calc_OrderQty”,“_JobHead_Calc_StockQty”,“_JobHead_Calc_UserName”,“_JobHead_Calc_XPartNum”,“_JobAsmbl_RptLanguageID”,“_JobAsmbl_AssemblySeq”,“_JobAsmbl_Company”,“_JobAsmbl_FinalOpr”,“_JobAsmbl_JobNum”,“_JobAsmbl_Calc_AttributeSetShortDescription”,“_JobAsmbl_Calc_BCAsmSeq”,“_JobAsmbl_Calc_BCJobNum”,“_JobAsmbl_Calc_BCPartNum”,“_JobAsmbl_Calc_BCRevNum”,“_JobAsmbl_Calc_comment”,“_JobAsmbl_Calc_NewPage”,“_JobAsmbl_Calc_ParentDesc”,“_JobAsmbl_Calc_ParentNum”,“_JobAsmbl_Calc_PartUDChr1”,“_JobAsmbl_Calc_PartUDChr2”,“_JobAsmbl_Calc_PartUDChr3”,“_JobAsmbl_Calc_PartUDChr4”,“_JobAsmbl_Calc_PartUDDat1”,“_JobAsmbl_Calc_PartUDDat2”,“_JobAsmbl_Calc_PartUDDat3”,“_JobAsmbl_Calc_PartUDDat4”,“_JobAsmbl_Calc_PartUDDec1”,“_JobAsmbl_Calc_PartUDDec2”,“_JobAsmbl_Calc_PartUDDec3”,“_JobAsmbl_Calc_PartUDDec4”,“_JobAsmbl_Calc_PartUDInt1”,“_JobAsmbl_Calc_PartUDInt2”,“_JobProd_RptLanguageID”,“_JobProd_Company”,“_JobProd_JobNum”,“_JobProd_OrderLine”,“_JobProd_OrderNum”,“_JobProd_OrderRelNum”,“_OrderRel_RptLanguageID”,“_OrderRel_Company”,“_OrderRel_OrderLine”,“_OrderRel_OrderNum”,“_OrderRel_OrderRelNum”,“_OrderRel_Room_Number_c”,“_OrderRel_SysRowID”,“_OrderDtl_RptLanguageID”,“_OrderDtl_Company”,“_OrderDtl_OrderLine”,“_OrderDtl_OrderNum”,“_OrderDtl_ProjectID”,“_Project_RptLanguageID”,“_Project_Company”,“_Project_Description”,“_Project_ProjectID”,“_Project_ProjectManager_c”,“_Project_SysRowID”,“_UD31_RptLanguageID”,“_UD31_Company”,“_UD31_GlobalLock”,“_UD31_GlobalUD31”,“_UD31_Key1”,“_UD31_Key2”,“_UD31_Key3”,“_UD31_Key4”,“_UD31_Key5”,“_UD31_SysRevID”,“_UD31_SysRowID”,“_UD31_AluminumColor_c”,“_UD31_Back_Tube_Width_c”,“_UD31_BackChainLength_c”,“_UD31_BackControlSide_c”,“_UD31_BackFabric_c”,“_UD31_BackHemBar_c”,“_UD31_BackPrivacyTrack_c”,“_UD31_BackRollDirection_c”,“_UD31_BackTubeSize_c”,“_UD31_Bedding_Item_c”,“_UD31_Bottom_Hem_c”,“_UD31_Bracket_c”,“_UD31_Center_c”,“_UD31_Closure_c”,“_UD31_Component_Name_c”,“_UD31_Component1_c”,“_UD31_Component2_c”,“_UD31_Component3_c”,“_UD31_Component4_c”,“_UD31_Cut_Length_c”,“_UD31_Cut_Width_c”,“_UD31_Date_Time_c”,“_UD31_Drapery_Item_c”,“_UD31_Draw_c”,“_UD31_Drop_c”,“_UD31_ExHBStickLen_c”,“_UD31_ExHemBar_PartDesc_c”,“_UD31_ExHemBar_PartNum_c”,“_UD31_Extrusion_Desc_c”,“_UD31_Fabric_Color_c”,“_UD31_Fabric_Part_Num_c”,“_UD31_Fabric_Width_c”,“_UD31_Fabric1_c”,“_UD31_Fabric2_c”,“_UD31_Fabric3_c”,“_UD31_Fabric4_c”,“_UD31_Fascia_c”,“_UD31_Fascia_Combined_c”,“_UD31_Fascia_PartDesc_c”,“_UD31_Fascia_PartNum_c”,“_UD31_Fascia_Width_c”,“_UD31_FasciaStickLen_c”,“_UD31_Fill_c”,“_UD31_Finished_Height_c”,“_UD31_Finished_Length_c”,“_UD31_Finished_Thickness_c”,“_UD31_Finished_Width_c”,“_UD31_Flange_Dim_c”,“_UD31_Fraction_Widths_1_2_c”,“_UD31_Fraction_Widths_1_3_c”,“_UD31_FrontChainLength_c”,“_UD31_FrontControlSide_c”,“_UD31_FrontFabric_c”,“_UD31_FrontHemBar_c”,“_UD31_FrontPrivacyTrack_c”,“_UD31_FrontRollDirection_c”,“_UD31_FrontTubeSize_c”,“_UD31_Fullness_c”,“_UD31_Horizontal_Repeat_c”,“_UD31_Hugger_c”,“_UD31_InHBStickLen_c”,“_UD31_InHemBar_PartDesc_c”,“_UD31_InHemBar_PartNum_c”,“_UD31_Insert_Size_c”,“_UD31_Insert_Type_c”,“_UD31_Item_Type_c”,“_UD31_Joining_Method_c”,“_UD31_Lining_c”,“_UD31_Motor_c”,“_UD31_Mount_c”,“_UD31_Mount_Position_c”,“_UD31_Notes_c”,“_UD31_Num_of_Pleats_c”,“_UD31_OrderLine_c”,“_UD31_OrderNum_c”,“_UD31_OrderRel_c”,“_UD31_Panel_Side_c”,“_UD31_Perimeter_c”,“_UD31_Pillow_Type_c”,“_UD31_Preseam_Widths_c”,“_UD31_PrivacyTrack_c”,“_UD31_Quantity_c”,“_UD31_Quilt_Pattern_c”,“_UD31_Quilting_c”,“_UD31_Railroad_c”,“_UD31_Railroad2_c”,“_UD31_Railroad3_c”,“_UD31_Railroad4_c”,“_UD31_Railroaded_c”,“_UD31_re_Bracket_c”,“_UD31_re_Chain_c”,“_UD31_re_Clutch_c”,“_UD31_re_Fascia_c”,“_UD31_re_Motor_c”,“_UD31_re_Remote_c”,“_UD31_re_SideChannel_c”,“_UD31_re_SillChannel_c”,“_UD31_Remote_c”,“_UD31_Replacement_c”,“_UD31_Required_Length_c”,“_UD31_Required_Width_c”,“_UD31_Return_Specs_c”,“_UD31_Rod_Width_c”,“_UD31_Room_Num_c”,“_UD31_RSItem_c”,“_UD31_SetStops_c”,“_UD31_Sew_In_Comments_c”,“_UD31_Side_Hem_c”,“_UD31_SideChannel_PartDesc_c”,“_UD31_SideChannel_PartNum_c”,“_UD31_SideStickLen_c”,“_UD31_SillChannel_PartDesc_c”,“_UD31_SillChannel_PartNum_c”,“_UD31_SillStickLen_c”,“_UD31_Single_Widths_c”,“_UD31_Stiffener_c”,“_UD31_Top_Treatment_c”,“_UD31_Treatment_System_c”,“_UD31_Tube_PartDesc_c”,“_UD31_Tube_PartNumber_c”,“_UD31_TubeStickLen_c”,“_UD31_User_ID_c”,“_UD31_Vertical_Repeat_c”,“_UD31_Welt_Size_c”,“_UD31_Widths_Needed_c”,“_UD31_WindowDepth_c”,“_UD31_WindowHeightDetails_c”,“_UD31_WindowWidthDetails_c”,“_UD31_Zipper_c”
“enu”,“14233WP”,“030018-8-1”,“SINGLE SHADE 70.875W x 59.75L”,“0”,“2640 47TH STREET S”,“”,“”,“FARGO”,“United States”,“9286549”,“BRANDT HOSPITALITY GROUP”,“ND”,“58104”,“”,“False”,“8.00000000”,“0”,“MTaj”,“”,“enu”,“0”,“14233WP”,“90”,“030018-8-1”,“”,“”,“”,“”,“”,“Nominal dimensions RS - Front 110-00012 - Qty: 1 Fabric: 110-00012 Cut Dim: 69.500"” W x 74.750"" L Cut Dim w/ Repeat: 69.500"" W x 74.750"" L Finished Dim: 70.875"" W x 59.750"" L “,“False”,”“,”“,”“,”“,”“,”“,”“,”“,”“,”“,“0”,“0”,“0”,“0”,“0”,“0”,“enu”,“14233WP”,“030018-8-1”,“8”,“30018”,“1”,“enu”,“14233WP”,“8”,“30018”,“1”,“007”,“3c843903-1dc6-4e96-b733-06e4aa422e1d”,“enu”,“14233WP”,“8”,“30018”,“20029”,“enu”,“14233WP”,“CWS - Lake Charles LA","20029","2","4b314857-dac2-4cb0-b3a1-1b9fecbae656","enu","14233WP","False","False","OrderDtl","30018","8","SINGLE SHADE 70.875W x 59.75L","1","-7921585423875309568","4dc0ad2d-5494-458c-939f-9989f8726e8a","","69.50","0.00","","","","False","","0.00","","","5"" Bracket","False","","Front","","","","","74.75","69.50","","","","0.00","16.00","","EXHemBar_PN_Placeholder","","","","94.00","","","","","5x2.5"" Fascia","False","","Fascia_PN_Placeholder","70.75","16.00","","0.00","59.75","0.00","59.75","","0","0","59.28","LT","110-00012","IN","True","SR","1.50","0.00","0.00","False","16.00","","InHemBar_PN_Placeholder","","","","","","None","IM","","","0.00","8","30018","0","","","","0","SDW","1.00","","False","False","False","False","False","False","False","False","False","False","False","False","False","False","None","False","74.75","69.50","","0.00","","Single Shade","No - Set in Field","","","","","15.00","","","18.00","0","","","","","Tube_PN_Placeholder","16.00","","0.00","","70.88","6.00","","","" "enu","14233WP","030018-8-1","SINGLE SHADE 70.875W x 59.75L","0","2640 47TH STREET S","","","FARGO","United States","9286549","BRANDT HOSPITALITY GROUP","ND","58104","","False","8.00000000","0","MTaj","","enu","0","14233WP","90","030018-8-1","","","","","","","","","","","","","","","","","","","","","","","","enu","14233WP","030018-8-1","8","30018","1","enu","14233WP","8","30018","1","007","3c843903-1dc6-4e96-b733-06e4aa422e1d","enu","14233WP","8","30018","20029","enu","14233WP","CWS - Lake Charles
LA”,“20029”,“2”,“4b314857-dac2-4cb0-b3a1-1b9fecbae656”,“enu”,“14233WP”,“False”,“False”,“OrderDtl”,“30018”,“8”,“SINGLE SHADE 70.875W x 59.75L”,“1”,”-7921585423875309568",“4dc0ad2d-5494-458c-939f-9989f8726e8a”,“”,“69.50”,“0.00”,“”,“”,“”,“False”,“”,“0.00”,“”,“”,“5"” Bracket",“False”,“”,“Front”,“”,“”,“”,“”,“74.75”,“69.50”,“”,“”,“”,“0.00”,“16.00”,“”,“EXHemBar_PN_Placeholder”,“”,“”,“”,“94.00”,“”,“”,“”,“”,“5x2.5"” Fascia",“False”,“”,“Fascia_PN_Placeholder”,“70.75”,“16.00”,“”,“0.00”,“59.75”,“0.00”,“59.75”,“”,“0”,“0”,“59.28”,“LT”,“110-00012”,“IN”,“True”,“SR”,“1.50”,“0.00”,“0.00”,“False”,“16.00”,“”,“InHemBar_PN_Placeholder”,“”,“”,“”,“”,“”,“None”,“IM”,“”,“”,“0.00”,“8”,“30018”,“0”,“”,“”,“”,“0”,“SDW”,“1.00”,“”,“False”,“False”,“False”,“False”,“False”,“False”,“False”,“False”,“False”,“False”,“False”,“False”,“False”,“False”,“None”,“False”,“74.75”,“69.50”,“”,“0.00”,“”,“Single Shade”,“No - Set in Field”,“”,“”,“”,“”,“15.00”,“”,“”,“18.00”,“0”,“”,“”,“”,“”,“Tube_PN_Placeholder”,“16.00”,“”,“0.00”,“”,“70.88”,“6.00”,“”,“”,“”
Is there something in the label file itself that is saying to print two copies?
