Base Processing BPM
Just created the base process with a comment in the 4GL code on our test server & the base method is not triggering at all. I have to add the disclaimer that this is Very dangerous & could cause all sorts of data issues, but it will work for what we need as long as the method only validated the lot number & nothing else.
--- In vantage@yahoogroups.com, "dansirow" <dansirow@...> wrote:
> Yes Base Processing BPM run in place of the standard BO.<br><br>I have used it to bypass a BO.  In E9 there is a new feature for internal cross reference numbers.  I do not want these used in Sales Order Entry, so I made a base BPM that just contains progress code with a comment.<br><br>This can be very dangerous, I would only use with extreme caution.<br><br>Dan Sirow<br>Independent Components Corp.<br><br>--- In vantage@yahoogroups.com, "Michael McWilliams" mmcwilliams22@ wrote:<br>><br>> During the Webex there was not any talk about base processing. From what I know this actually completly overrides the Method called by the BO. I am pretty sure this can be dangerous if you do not know exactly what you are doing. I would like to find out more about this portion of BPMs though. For example, during receipt entry every time a new lot is created it asks. Would you like to create a new lot. In our environment every receipt line is a new lot & most receipts have 20 or more lines.<br>> <br>> Epicor.Mfg.Proxy.ReceiptImpl.CheckDtlLotInfo is the method being called & from the source it says:<br>> This method returns an error or question if the LotNum field does not exist depending upon the security of the user.(by the way, It would be great if there was a place that describes every BO method like the source code does)<br>> <br>> In theory using base processing could I ignore this method?<br>> <br>> Do we have anybody on the group who has created or bypassed a base method using a BPM?<br>><br>
Michael,
Actually we did talk about Base Processing; you'll be able to see that
in the power point and the recording. My perception or spin was the
same as yours. I have not yet to date tried to develop a practical
application to address a business case using Base Processing. Frankly
I'd love to see and hear more from Epicor and what they think about this
type of directive and put a little more information out there on it.
Rob Bucek
Manufacturing Engineer
PH: 715-284-5376 ext 311
FAX: 715-284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site)
Of Michael McWilliams
Sent: Friday, June 05, 2009 11:46 AM
Subject: [Vantage] Base Processing BPM
source code does)
method using a BPM?
Yes, I did see where it was briefly talked about.
I would love if anybody could chime in on more details about the base
processing. I think I recall hearing somewhere that it requires additional config to be done on the server end but I am not 100% sure about tha.
--- In vantage@yahoogroups.com, "Rob Bucek" <rbucek@...> wrote:
> Michael,
> Rob Bucek
> FAX: 715-284-4084
> source code does)
> method using a BPM?
I didn't get into .net actions either because to use those you do have
to actually install and setup what they call a BPM server. Something
more than what's normally installed, that and development and deployment
of the .asp pages make it a lot more daunting for the average user
(include me in that group).
Rob Bucek
FAX: 715-284-4084
Sent: Friday, June 05, 2009 11:56 AM
Subject: [Vantage] Re: Base Processing BPM
about tha.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Rob
> Michael,
this
> Rob Bucek
> FAX: 715-284-4084
> <http://www.dsmfg.com/ <http://www.dsmfg.com/> >
Behalf
what
I
you
environment
called
> source code does)
> method using a BPM?
Yes Base Processing BPM run in place of the standard BO.<br><br>I have used it to bypass a BO.  In E9 there is a new feature for internal cross reference numbers.  I do not want these used in Sales Order Entry, so I made a base BPM that just contains progress code with a comment.<br><br>This can be very dangerous, I would only use with extreme caution.<br><br>Dan Sirow<br>Independent Components Corp.<br><br>--- In vantage@yahoogroups.com, "Michael McWilliams" <mmcwilliams22@...> wrote:<br>><br>> During the Webex there was not any talk about base processing. From what I know this actually completly overrides the Method called by the BO. I am pretty sure this can be dangerous if you do not know exactly what you are doing. I would like to find out more about this portion of BPMs though. For example, during receipt entry every time a new lot is created it asks. Would you like to create a new lot. In our environment every receipt line is a new lot & most receipts have 20 or more lines.<br>> <br>> Epicor.Mfg.Proxy.ReceiptImpl.CheckDtlLotInfo is the method being called & from the source it says:<br>> This method returns an error or question if the LotNum field does not exist depending upon the security of the user.(by the way, It would be great if there was a place that describes every BO method like the source code does)<br>> <br>> In theory using base processing could I ignore this method?<br>> <br>> Do we have anybody on the group who has created or bypassed a base method using a BPM?<br>><br>
