Hi all,
Looking for input on the right approach for a specific scenario in Kinetic.
Scenario
We have a part, let’s call it PART-10, which is cut from a longer raw material stock item, PART-20. Right now PART-10 is set up as a standalone Purchased part with no BOM, so its cost has no relationship to the raw material it’s actually cut from, and the cutting charge isn’t captured anywhere.
What we want to achieve, for just this one part
PART-10’s cost should reflect a proportional share ofPART-20’s cost (e.g., half the raw material, since it’s half the length), plus a fixed cutting charge- This cost needs to flow correctly into Job costing when a job is created for
PART-10
Our current plan
- Reclassify
PART-10from Purchased → Manufactured - Build a Method of Manufacturing:
- PartMtl line pointing to
PART-20(QtyPer = 0.5) - PartOpr line for a CUTTING operation carrying the fixed charge
- Run Cost Rollup and confirm Job Entry pulls the method correctly
Questions for the community
- Is this the right way to model a “fractional length” BOM relationship, or is there a better native pattern for this (e.g., Configurator) even for a single, fixed-length part?
- Any gotchas with QtyPer/UOM when the quantity represents a proportional length rather than a whole unit?
- Best way to capture the fixed cutting charge on the operation — Misc Charge vs. calculated setup/run hours?
- Anything to watch for with MRP once
PART-20has independent demand (sold on its own) in addition to being consumed byPART-10?
Once we’ve got this working cleanly for one part, we’re looking to apply the same pattern across a larger set of similar parts — but want to get the single-part approach validated first.
Thanks for any insight!
Tags: Engineering Workbench, BOM, Costing, Method of Manufacturing, MRP
