Best method for job traveler report default
Hi Brian,
> I'm looking for the best method to customize the job traveler report
> default options. We want the operation standards checkbox to default to
> checked, with the option to turn it off. Epicor 9.05.603.
> Is there a better place to set this default?
Not in the office, but if I understand you, you can choose the options
that you want to save and then click on the Options menu item and save
them. I believe this is a user-by-user thingy.
Mark W.
A trace showed a call to BO Epicor.Mfg.Rpt.JobTrav method
GetNewParameters, which sounds like the right place, but I didn't find
this method available when creating a BPM.
Instead, I created a form customization in
Rpt.JobTravJobEntry.JobTravForm, on form load, and used
GetNativeControlReference to mark it checked in the UI. This worked,
but then I discovered that the Job Traveler form on the main menu is a
different form then the one called from Job Entry.
And then I wondered about auto printing job travelers (which we don't do
yet) and what defaults they would use...
Brian.
