Can I block the serial number from a part number? This to cannot shipped a part and prevent that a shipment contain a piece with a SN that is blocked?
The best bet is a BPM at one of the key points.
You will need a UD field on the SerialNo table. The one of these:
-Data Directive on SNTran (possibly)
-Method Directive on the available SN in Serial Selection
-Method Directive on CustShip.Update
There are possibly more, but that should help get you started.
thank you Jason
Which are the other possible options? Would you might share them?
Thank you,
Luis Peralta
What did you already try? The option provided are the best options I can think of based on what you’ve shared.
