BOM Listing
I’m seeing different data in BOM reports than other people are (and I believe they are seeing the correct data).
As an example, Part SKP100 BOM I am seeing Rev B for part SKP200 while others are seeing the correct Rev F.
I expanded the filter screen to show more info and in doing so noticed the Effectivity Date of 6/28/22.
If I set that Effectivity Date to today I then see the correct Rev F for part SKP200 on BOM SKP100.
However, if I close and restart Kinetic the Effectivity Date of 6/28/22 returns for this BOM.
any thoughts
Can’t say this is what happened or not, but in the overflow menu for BOM Listing there is a “Save Defaults”, “Get Defaults” and “Remove Defaults”.
I wonder if at some point you changed the date to 6/28/22 and Saved Defaults? May not have been on purpose.
But try to “Remove Defaults” and then leave the form and come back and see what date shows up.
