Hi,
I'm trying to use the BomSearchAdapter to get a PartMtl record in an external .NET program. But no matter what I pass into the GetByID method, I get back an empty row.
Here's my code:
Dim dt As DataTable
partMtlAdptr = New Erp.Adapters.BomSearchAdapter(epiLaunch)
partMtlAdptr.BOConnect()
partMtlAdptr.GetByID("Something here")
dt = partMtlAdptr.BomSearchData.PartMtl
I've tried passing into GetByID the PartNum, the MtlPartNum, the SysRowID and just about every combination of variables as a ParamArray. No matter what I pass in I get nothing back.
Does anybody know how to get a PartMtl row back in a .NET program?
the BL tester install file is on the app server Epicor905\Utilities\BL-Tester directory.
Sent: Monday, July 27, 2015 4:24 PM
Subject: [Vantage] Re: BomSearchAdapter PartMtl GetByID
Jim,
Thanks for replying. I don't have the BL tester. We are not licensed for the SDK.
Bryce
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
I would assume so, but I don’t know. I have only installed 10 one time. I am waiting for the dust to settle before moving.
Sent: Monday, July 27, 2015 6:55 PM
Greg,
Thanks! I never knew that was there. Do you know if they have a BL-Tester for Epicor 10?
Bryce
