no ideas?
--- In vantage@yahoogroups.com, "laidig.systems" <laidig.systems@...>
wrote:
> I am able to see my workflow being called but I can't figure out how
> to read the data. I don't know what schema to use for the first
> webservice after being triggered to start from BPM. For instance, BPM
> fires a Service connect workflow from the SalesOrderEntry Update. For
> my first webservice, what is the input schema? Is it
> SalesOrderService>update response or SalesOrderService>update request?
> or do i have to save something to an xml file and use generate schema
> to create my own input? THanks!
> --- In vantage@yahoogroups.com, "Cathlene Fishman" <fish@> wrote:
> > As of ESC 8.2
> > Go to Service Connect Workflow and in File, Process Properties,
> > Document Tracking ... set it to required ...
> > Fire off BPM and be sure to look Inbound Documents, all events to see
> > if the workflow was fired off ..
