BPM Code on PO Business Object (8.03.408B)
I actually do have the directive setup on the "Update" method and not the "ChangeDetailOurCalcQty."
To: melissa hietala <kevmel822@...>; vantage@yahoogroups.com
Sent: Fri, November 13, 2009 11:55:10 AM
Subject: Re: [Vantage] BPM Code on PO Business Object (8.03.408B)
I'm just wondering why did you do it on that method
instead of Update(save)
Its almost saying that no change happened thus the error message
Sent from my Verizon Wireless BlackBerry
Date: Fri, 13 Nov 2009 08:23:00 -0800 (PST)
To: <vantage@yahoogroups.com>
Subject: [Vantage] BPM Code on PO Business Object (8.03.408B)
Â
Hello all,
Â
I have the following 4GL code written for a BPM. The info messages and assign statements seem to be working as expected. However, after initially saving a record, seeing the info messages launch, and attempting make a change, I am randomly getting this error message shown below. Any thoughts on what may be causing this or how I can adjust my code to eliminate this? Thank you.
Dustin Biniek
Â
Â
•Find First ttPODetailwhere ttPODetail.RowMod= "A" no-error.
•If available ttPODetailthen do:
•find first part where part.company= ttPODetail.Companya nd Part.partnum= ttPODetail.PartNumn o-lock no-error.
•If not available part then do:
•{lib/PublishInfoMsg .i&InfoMsg= "'Is this a taxable part?'"}.
•end.
•If available Part then do:
•If ttpodetail.taxable= True then return.
•end.
•If ttpodetail.taxable= false then do:
•If part.checkbox10 = False then do:
•end.
•If part.checkbox10 = True then do:
•assign ttpodetail.taxable= part.checkbox10.
•{lib/PublishInfoMsg .i&InfoMsg= "'Taxable status has been updated.'"}.
•end.
•end.
•end.
Â
Exception caught in: Epicor.Mfg.BO. PO
Error Detail
Message: No adjustments made
Type: Error
Program: Server/bo/PO. p
Method: ChangeDetailCalcOur Qty
Table:
Row:
Field:
Â
Â
Stack Trace
at Epicor.Mfg.Proxy. POImpl.ChangeDet ailCalcOurQty( Decimal newCalcOurQty, PODataSet ds)
at Epicor.Mfg.UI. Adapters. POAdapter. ChangeDetailCalc OurQty(Decimal newCalcOurQty)
Â
Hello all,
Â
Dustin Biniek
Â
Â
•find first part where part.company= ttPODetail.Companyand Part.partnum= ttPODetail.PartNumno-lock no-error.
•{lib/PublishInfoMsg.i&InfoMsg= "'Is this a taxable part?'"}.
•end.
•end.
•end.
•{lib/PublishInfoMsg.i&InfoMsg= "'Taxable status has been updated.'"}.
•end.
•end.
•end.
Â
Exception caught in: Epicor.Mfg.BO.PO
Error Detail
Type: Error
Program: Server/bo/PO.p
Method: ChangeDetailCalcOurQty
Table:
Row:
Field:
Â
Â
Stack Trace
at Epicor.Mfg.Proxy.POImpl.ChangeDetailCalcOurQty(Decimal newCalcOurQty, PODataSet ds)
at Epicor.Mfg.UI.Adapters.POAdapter.ChangeDetailCalcOurQty(Decimal newCalcOurQty)
Â
Hello all,
Â
Dustin Biniek
Â
Â
•end.
•end.
•end.
•end.
•end.
•end.
Â
Error Detail
Type: Error
Table:
Row:
Field:
Â
Â
Stack Trace
Â
