BPM Error
Hi there,
I created a BPM based on the following conversation:
Essentially I wanted the customer type to default to “Customer” and terms to default to “Net 30 Days”.
However, I’m getting an error now when creating a new customer:
Funny enough, if I manually reselect “Customer” and “Net 30 Days”, the error goes away.
Does anyone know why this might be happening?
“Customer” is probably the description/Name for that type record. You’ll need to use that code for that type. Probably is “CUS”.
As for the Terms, you need to specofy the terms code, not the description
Use the value from this column for the term you want:
As @ckrusen mentioned, its customer type codes CUS, SUS and PRO and terms code
Bingo. Thanks guys.
