Dale,
Thanks for the advice, I'll get working on it now and let you know if it worked.
Best,
Michelle de la Vega
Business Applications Manager
Cold Jet, LLC
455 Wards Corner Road
Loveland, Ohio 45140
USA
+1 513-716-6400 (office)
+1 513-382-3281 (mobile)
+1 513-831-1209 (fax)
www.coldjet.com<http://www.coldjet.com>
[cid:image001.jpg@01CA8321.10E12370]
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Dale Schuerman
Sent: Tuesday, December 22, 2009 3:35 PM
Subject: RE: [Vantage] BPM for Transfer Order Receipts
Here are a couple things to try.
1. Add "or ttTFShipDtl.RowMod = 'U' " to the Find First
ttTFShipDtl.
Depending on the Business Object the RowMod may be a "U"
2. Do a Find First on the PlantWhse
This should not happen but if there are multiple records that match the
where clause a Find will fail.
Dale E. Schuerman
Senior Consultant
Epicor Certified Consulting Partner
RAM Software Systems, Inc.
972-669-0763 x233 (voice)
972-669-9603 (fax)
mailto:dale.schuerman@...<mailto:dale.schuerman%40ramsys.com>
<BLOCKED::blocked::mailto:dale.schuerman@...<mailto:dale.schuerman%40ramsys.com>> (email)
http://www.ramsys.com <BLOCKED::blocked::http://www.ramsys.com/>
(website)
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of Michelle de la Vega
Sent: Tuesday, December 22, 2009 1:52 PM
Subject: [Vantage] BPM for Transfer Order Receipts
I am trying to write a 4GL BPM to assign the primary bin location to the
transfer order receipts. Currently, the primary bin does not default on
transfer orders so instead of looking up each line one at a time, I'm
trying to auto assign the bin. However, it doesn't seem to be working...
Here is my pre-processing code:
Find first ttTFShipDtl where ttTFShipDtl.RowMod = 'A' NO-LOCK NO-ERROR.
If available ttTFShipDtl then do:
DEFINE VARIABLE BIN AS Character NO-UNDO.
BIN=''.
Find PlantWhse WHERE ttTFShipDtl.Company = PlantWhse.Company AND
ttTFShipDtl.PartNum = PlantWhse.partnum and ttTFShipDtl.WarehouseCode =
PlantWhse.WarehouseCode and plantwhse.plant = CUR-PLANT NO-LOCK
NO-ERROR.
if available PlantWhse then do:
BIN = Plantwhse.PrimBin.
Assign ttTFShipDtl.BinNum = BIN.
end.
end.
If anyone has any ideas I would greatly appreciate it.
Michelle de la Vega
Cold Jet, LLC
USA
[cid:image001.jpg@01CA8316.443E6760<mailto:image001.jpg%4001CA8316.443E6760>
<mailto:image001.jpg%4001CA8316.443E6760> ]
Attention:
This email message is privileged and confidential. If you are not the
intended recipient please delete the message and notify the sender.
Any views or opinions presented are solely those of the author.
This email message has been scanned for Viruses and Content and cleared
by MailMarshal SMTP
For more information go to http://www.ramsys.com
Best,
Michelle de la Vega
Cold Jet, LLC
USA
ttTFShipDtl.
Dale E. Schuerman
Senior Consultant
972-669-9603 (fax)
(website)
BIN=''.
NO-ERROR.
end.
end.
Michelle de la Vega
Cold Jet, LLC
USA
Attention:
by MailMarshal SMTP
